1965 Cutlass was tilt a option or available?
https://www.ebay.com/itm/1964-65-66-...QAAOSwaeRZIz8B
This is what they look like. This one is missing some parts, but it is a correct column for the car. There were both column shift and floor shift columns. There are several differences in the non tilt and tilt columns. Turn signal switches do not interchange, the lower flange for the rag joint are welded on a non tilt but removable on tilt. If there are missing parts they can be elusive but are usually found.
65 and 66 use the same column, maybe 64 but I have no first hand knowledge of the 64 Cutlass. I put a tilt column in the blue 66 which was sold to me by Chris Whitt, if I got his name mis-spelled I apologize.
67442nut
April 4th, 2016 11:55 AM
