front coil overs for 69 cutlass vert
Old January 23rd, 2015, 04:24 PM
luddie's Avatar
I am thinking about buying front coil overs (QA1) for my worn out front suspension. They make different front end weight kits, how is this determined? This is all new to me and I'm not sure if the coil overs are the answer, any suggestions?
luddie is offline
Old January 23rd, 2015, 04:41 PM
For what you'll pay for a pair of coilovers, you can replace the front springs and rebuild the whole front end.
oldcutlass is online now
Old January 25th, 2015, 11:25 AM
Mr Nick's Avatar
Coil-overs are an excellent upgrade, when needed. They only replace the spring and shock, any other worn out areas will still need to be addressed.
In my opinion, unless the rest of your steering & suspension is upgraded, you don't need coil-overs. The only exception to that would be if you are ultra picky about ride height.
You may find some "big block" and "small block" kits. That isn't enough info, and are generally based on a Chevelle with factory Chevy engines. AC (or lack of), aluminum intake, aluminum heads, relocated battery, and other things should be considered when choosing shocks/springs. Best to contact a few vendors and get suggestions.
Mr Nick is offline
hilbily
Suspension & Handling
July 15th, 2016 02:55 PM
AzChevs
June 29th, 2014 10:02 AM
tomc5
June 25th, 2014 08:09 PM
halfmoontrail
March 17th, 2013 10:28 AM
ah64pilot
April 19th, 2012 08:25 PM
Quick Reply: front coil overs for 69 cutlass vert
