Header in the way of LCA Bolt *HELP*
Old September 7th, 2014, 08:33 PM
SD72cutlass's Avatar
ok...i started some what rebuilding my front end, i just finished the passengers side. today i started the driver side thinking it would be done alot faster since i already did one side but no. previous owner put on some aftermarket headers "doug thorley" and the pipes are in the way of the lower control arm bolt. The header is off but i didn't want to completely remove it, so i tried to wiggle it around and get some space for that bolt but not enough room
I would pull the header totally off but the dip stick is in the way and it looks like the steering shaft might be as well?
any ideas or anyone thats dealt with this help me out
SD72cutlass is offline
Old September 8th, 2014, 06:21 AM
Remove the motor mount bolt and jack the engine up and out of the way to remove the header. Then proceed with your front end repair.
oldcutlass is offline
Old September 8th, 2014, 10:03 AM
Run to Rund's Avatar
If the header is hitting the nut and extended threads area, you can grind off the extra length, or in some positions you can reverse the direction of the bolt. If the bolt head is too thick, you can get a button head allen bolt.
Run to Rund is offline
Old September 8th, 2014, 12:18 PM
66400's Avatar
Might be able to cut off the offending bolt and replace it by inserting the bolt from the other direction.
Henry
66400 is offline
Old September 8th, 2014, 01:41 PM
GREAT ideas, i was just looking and was thinking about just cutting the bolt, since i live so close to napa i can just get another. Will the bolt be fine the other way?
Old September 8th, 2014, 02:05 PM
RandyS's Avatar
Sure, the bolt won't care...........
RandyS is offline
Old September 8th, 2014, 03:47 PM
Seems as if I wanted to do that back in the 90s and the frame was in the way of the rear LCA bolt. Been a long time and I may not be remembering correctly, though. Might be a viable option for the front LCA bolt.
Fun71 is offline
Old September 8th, 2014, 07:14 PM
Also don't completely remove the old bolt before starting the new one. The control arm will slide out of position due to spring tension.
Old September 9th, 2014, 03:03 PM
i got both controll arms off, New bushings today and ball joints thank you!!
Old February 13th, 2018, 05:27 PM
Bryan Burch's Avatar
Search function saved me. I cut that booger off and inserted the new one from the other direction.
https://photos.app.goo.gl/PjfwTqEtCEeFaJ4k1
https://photos.app.goo.gl/onJQCiVMntO27sut1
Bryan Burch is offline
big_wheel1971
Suspension & Handling
June 28th, 2011 07:15 PM
oldzy
June 19th, 2011 07:56 PM
oldzy
June 7th, 2011 12:11 PM
oldzy
January 2nd, 2011 04:20 PM
Quick Reply: Header in the way of LCA Bolt *HELP*
