Disk brake conversion - Stabilizer bolts close to spindle
Old July 20th, 2014, 05:28 PM
c-towndave's Avatar
I am getting the front end back together and am doing an after-market disk brake conversion at the same time. After getting things in place I now see that the stabilizer bolts come very close to the new disk brake spindle (see photos).It is not as bad on the RH side, but still kind of close. Is this something that I need to be concerned about and is there an adjustment that I can make to reduce the chance of interference?Right now the car has jack stands under the frame, so the front end is not under load.
Help/insight appreciated.
Dave
c-towndave is offline
Old July 20th, 2014, 05:47 PM
brddg's Avatar
Face the screw the other direction or get a shorter end link. I've had that issue before as I'm sure many here have. And don't forget the cotter pin on the upper balljoint!
brddg is offline
Old July 20th, 2014, 06:24 PM
oldscutty's Avatar
I just did the same thing. Do not fret once you put engine and tranny weight down on it you will see that gap increases to 3 inches roughly. Also I would put the bolt head on top.
oldscutty is offline
Old July 20th, 2014, 06:38 PM
Once the weight is on the ground you'll have plenty of clearance.
oldcutlass is online now
delmontcrusier
May 28th, 2023 07:37 AM
nolabigdawg
October 25th, 2014 11:50 AM
Troys Toy 70
Brakes/Hydraulic Systems
June 7th, 2012 04:29 PM
oldzy
April 1st, 2011 04:29 AM
perro
September 3rd, 2007 01:30 PM
Quick Reply: Disk brake conversion - Stabilizer bolts close to spindle
