Front end rebuild 68 442, coil spring insulator??
Old May 27th, 2014, 05:56 PM
.Rocket.Man.'s Avatar
I'm in the process of rebuilding/replacing the steering/suspension/brakes on my 68 442. I'm to the point where I have it all disassemled and ready to clean the control arms and prep for powder coating. When I pulled the old coil springs out I discovered rubber insulators that appear to act as a bushing between the spring and lower control arm.
I didnt realize they were there and looked for them on-line to get replacements but have'nt seen them on any of the main auto part resources, (OPGI, yearone, Rock auto, In-line tube). Do I need these? I'm sure they're factory original and assume theyre necessary? Any idea where I can get them?
I'll try and post some pics later. Also kinda surprised how easily things have came apart so far, was a little hesitant going into the project but so far it's been smooth.....of course I havent gotten to the more challenging part of putting it all together. Thanks in advance for any input.
.Rocket.Man. is offline
Old May 27th, 2014, 08:33 PM
Magna86's Avatar
There are no spring insulators in the front control arms that I have ever seen. My guess is someone installed them in the past. Maybe as spacer to increase the front end height..
Magna86 is offline
Old May 27th, 2014, 08:37 PM
Randy C.
rcorrigan5's Avatar
I believe the assembly manual shows them only for the rear springs.
Randy C.
rcorrigan5 is offline
Old May 28th, 2014, 06:52 AM
Randy C.
X2. I've never seen them on the fronts either.
joe_padavano is offline
Old May 28th, 2014, 07:40 AM
boese1978's Avatar
Did mine on a 68 awhile back, nothing in the front, one on each side in the rear.
boese1978 is offline
Old May 28th, 2014, 09:12 AM
member
olds1968's Avatar
Same here didn't have any up front when i did my front suspension and replaced the rear ones since they were coming apart.
olds1968 is offline
Old May 28th, 2014, 12:10 PM
Thanks ya'll, one less thing to fool with then!
Old May 28th, 2014, 12:50 PM
mpolds's Avatar
Front Coil Spring Insulators
Everyone I know puts them in.... Never a bad idea to have some rubber between two hefty pieces of metal, you know......
I have them for the fronts -- $ 8.00 for a pair -- can ship them via a padded manila envelope for $ 4.00.
Call me -- Craig -- 516 - 485 - 1935... New York..
mpolds is offline
Old May 28th, 2014, 01:32 PM
Nobody I know puts them in the front. I've seen solid spacers put under the spring, but nothing to isolate the spring from the perches.
oldcutlass is online now
442iowa
Suspension & Handling
February 13th, 2012 05:05 PM
boese1978
December 18th, 2011 06:41 AM
77GCSX
January 25th, 2011 02:53 AM
Longhorncutlass
March 2nd, 2009 01:53 PM
Quick Reply: Front end rebuild 68 442, coil spring insulator??
