Moog rear control arm bushing part #?
hi all - does anybody have correct part # for Moog upper and lower Rear control arm rubber bushings? It’s for a 72 cutlass convertible with 10 bolt - 8.5inch differential - I’m looking for all four lower and the four upper (upper has the “mouse ear” bushing on top of the housing) thanks! ~ Joe R.
I have it listed as all the bushings being the same, here is a photo of the bushing and the spacer used to install them. without the spacer I have collapsed the one side of the control arm.
Not only are all eight bushings exactly the same part number, but six bushings that go into the upper and lower control arms all get pressed in from the same direction. The arms are the same on each side - they are not RH/LH. Only the two bushings in the rear axle get installed in different directions.
it occurs to me that I’m not sure how sway bars attach to the lower control arms as mine has no sway bar (yet)
Does the long slot oval hole go towards the front of the car? (That would be my guess but just wanted a second opinion)
Yes the oval slot goes towards the front.
the arms you have do not look to be boxed for a sway bar are you going to use spacers or box the arms?
inserts to box the control arm
https://www.summitracing.com/parts/o...SABEgLey_D_BwE
Joe, do you have documentation on this?
Vistabrat72
February 22nd, 2018 05:35 PM
