Lowering 73 delta 88
Old April 7th, 2018, 08:19 PM
Kjack559's Avatar
whats the best way too lower my 73 delta 88 convertible?
ive read that 73 delta 88 can't be aligned properly if lowered , I am wanting too drop mine 3 inches, does anyone know a way?
Kjack559 is offline
Old April 8th, 2018, 06:59 AM
The problem with any long arm/short arm suspension system is that the camber changes as the tire travels up and down through the suspension arc of travel. If you lower the car by cutting the springs, static ride height now has the tire at a different point in the suspension travel than the factory design point. Trying to achieve the factory camber spec at this new ride height will be difficult if not impossible, since you may run out of available camber adjustment. Even if you are able to achieve the factory alignment, since the tires are on a different point in the camber curve, handling and tire motion will be different from what was intended.
The alternative is to use lowering spindles. This maintains the stock camber curve (and thus the stock alignment capability) since they raise the tire relative to the rest of the suspension without actually changing the suspension travel or geometry. Unfortunately, I do not know if lowering spindles are offered for your car. Any suspension parts for a 1971-76 Impala will fit your Olds, however, so there is a possibility.
joe_padavano is online now
malibru
16
July 9th, 2016 05:01 PM
Dead Reckon
Suspension & Handling
March 20th, 2015 08:27 AM
Theo's '67
March 28th, 2014 06:08 PM
MASH4077
26
July 19th, 2011 04:46 PM
eddiem06
December 24th, 2006 08:06 PM
Quick Reply: Lowering 73 delta 88
