Cutlass 66 shocks and springs
Need some help. I have some front tubular control arms wich will lower the car 1,5-2" with stock height spring and shocks. My car needs new springs and shocks so what to buy. I guess I need to order stock height for the front, could not lower it more in front. Found some shocks from Hotchkis, Sport Suspension Shock Absorbers 79010002. That I think will work, but what about the rear springs? Should I order 1 or 2" lowering springs or just stock height springs? Will the car have to much rake with stock springs in rear and 1,5-2" lowered front end?
Thanks..
Thanks..
First of all, I assume it is the lower control arms that you have that lower the car, correct? To lower the car, these arms must have either the spring pocket dropped. Effectively, this locates the spindle "higher" relative to the bottom of the spring when the weight of the car is on the spring, thus dropping the car over the tire. The spring remains at the stock compressed height, so you want to use stock length shocks and springs. I've found that about a 1-1.5" drop at the front end looks really good on the A-body cars, especially with a little "rubber rake" by using slightly staggered tire diameters.
You are right Joe about the control arms, in my case it will be new lower and upper arms. And I guess I order some stock height springs and shocks for front. Rear I need to figure out, keep it stock height or put in lowering springs. It would be Nice to see some picture of a car with either setup. Do you know some god stock spring brand?
All the bushings will be changed, rear control arms, body bushings, new springs and chocks, and new control arms in front. This is an old Arizona car so all rubber was bad.
I kind of like both tail down and up, but up looks more aggressive..
RetroRanger
February 25th, 2014 05:04 PM
