A Body Intermediate steering Shaft
Old August 31st, 2017, 06:06 AM
Alex72cutty's Avatar
The shaft on my car (Top) is worn out and need to be replace or rebuild. My question is an upgrade shaft available to improve steering.
Alex72cutty is offline
Old August 31st, 2017, 06:26 AM
How is the shaft worn out?
oldcutlass is online now
Old August 31st, 2017, 06:32 AM
The boot is ripped and I've never touched it since I had the car. Are bearings inside that coupler? I wasn't sure if it affects the feel of steering?
Old August 31st, 2017, 06:43 AM
Do you mean this? Upper or lower?
Old August 31st, 2017, 06:48 AM
The bottom image sir.
Old August 31st, 2017, 07:22 AM
The seal can be replaced. There is not much inside of that. The clip holds it together.
Old August 31st, 2017, 07:23 AM
Magna86's Avatar
If I'm not mistaken you can buy a new boot for the joint. Its like a CV joint. Remove the clip to remove boot then clean it out and repack with grease. Install new boot and good to go unless there is severe damage found inside.
Magna86 is offline
Old August 31st, 2017, 07:26 AM
Oh ok, not much to that at all. I'll look for the boot so I can repack and replace. Thanks fuys
Old August 31st, 2017, 07:31 AM
oddball's Avatar
Look at the Chevelle sites for the steering shaft parts - it's the same shaft in that year A bodies. Just clean it up and re-grease it. IIRC, need to press out the cross pin in order to get the boot off. Been a few years since I rebuilt mine.
A new ragjoint will do much more for improving steering feel, but nothing can help a steering gear that is sloppy.
oddball is offline
Old August 31st, 2017, 07:40 AM
I've changed the gear box with the GJC gearbox but it's leaking and I'm going to replace it. I replaced the rag joint as well. I bought the kit from Lee Engineering.
Old August 31st, 2017, 08:45 AM
I think you can take the rag joint bracket off and slide the rubber seal down the shaft.
Old August 31st, 2017, 09:21 AM
I'm curious why you think changing what is essentially a solid metal shaft can "improve" steering.
(Yes, I know it telescopes and has a u-joint at one end)
joe_padavano is offline
Old September 1st, 2017, 06:36 AM
It was just a thought. My car handles good. Maybe my standards are a little too high..lol I blame it on these new cars these days.
Old September 1st, 2017, 07:58 AM
Actually it does not telescope its got shear pins in it in case of an accident to allow it to collapse. Sorry Alex as much as you try it won't feel like rack and pinion.
Old September 1st, 2017, 08:12 AM
The boot is not that easy to replace as everyone seems to think.
Allan R is offline
Old September 1st, 2017, 08:47 AM
There are a number of things you can do to an A-body to improve steering response. Changing the steering shaft isn't one of them. ASSUMING all steering parts are in good shape and not worn, the easiest thing to do is to crank in as much positive caster as possible with the stock suspension design. When new, these cars had zero or slightly negative caster. This made steering easy (especially with manual steering) but hurt stability and steering feel. This caster angle is one of the big differences in newer cars. Of course a quick ratio box will also be a big improvement.
501Paratrooper
Suspension & Handling
31
February 7th, 2019 11:30 AM
skryla
May 23rd, 2012 12:22 PM
olds70supreme
June 30th, 2011 07:35 PM
starfire
April 29th, 2011 02:38 AM
xx69442
October 14th, 2010 04:39 PM
Quick Reply: A Body Intermediate steering Shaft
