Steering shaft removal 64' Cutlass???
1964 F85/Cutlass--
Can anyone shed some insight on how to get the steering shaft removed, or at least pulled up a couple of inches.
Trying to fit some headers with my LS2 swap and think they'll work of I could just get the shaft out for install.
Much appreciated!
Dan
Much appreciated!
Dan
Update
I found my answer over on ls1tech.
If anyone finds this and is curious, you can either pull the steering wheel off and the shaft comes out through the front, or a simpler way is to pull the entire column.
Cheers!
Cheers!
Alex72cutty
Suspension & Handling
15
September 1st, 2017 08:47 AM
