steering box replacement.
Old March 25th, 2010, 08:30 PM
  #41
rktolds's Avatar
Thanks. So the air rises to the top of the pump?
Matt
rktolds is offline
Old March 25th, 2010, 08:47 PM
  #42
Hangin' out...
henryk8398's Avatar
Matt
Yes. As you work the steering wheel to the left and right air bubbles will make their way to the top of the pump. Your fluid will appear foamy, but that will eventually settle down. You may have to check it a couple of times.
henryk8398 is offline
Old March 26th, 2010, 09:08 AM
  #43
Jaybird's Avatar
Will this steering box replacement also work on by "B body" car,
67 delta 88?
Jaybird is offline
Old March 26th, 2010, 10:59 AM
  #44
Hangin' out...
henryk8398's Avatar
67 delta 88?
It really comes down to the "gear sweep". The boxes interchange, but having, for example an F-Body Box on an A-Body will result in a larger turning radius. You don't want that. You need to determine how many degrees your pitman arm swings from extreme left to extreme right. IIRC:
-Stock A-Body (1964-1972) 40degrees
-Stock F-Body (2nd Gen) 35 degrees
-1992-1998 Grand Cherokee 41 degrees (This is why they work so well for the A-Body).
Bear in mind, that a competent steering box specialist can reconfigure the stops. You could too if you knew what you were doing.
If your Delta has the same type of Saginaw Box (I don't know for sure), it would at least bolt in. But I guess you have some homework to do. It makes me wonder, maybe a box from a later model B/C body would be the ticket? I love the steering on my 98 Regency. It's responsive and has good turning radius for a large car. If that would work, the rest of the swap procedure should be the same as far as adapters and a new coupler are concerned.
Old March 26th, 2010, 10:12 PM
  #45
Jaybird's Avatar
Hey henryk8398: Thanks for the quick reply. I happen to own a 96 Jeep Grand Cherokee. I could test things without having to purchase a steering box.
If any else would like to add their 2-cents worth, please do!
Jaybird
Jaybird is offline
Old March 27th, 2010, 02:52 AM
  #46
rcdynamic88's Avatar
Just get a new quick ratio manual steering box and pitch the power steering altogether. Gain some HP and have real road feel, pwer steering is for old ladies!
rcdynamic88 is offline
Old March 27th, 2010, 01:35 PM
  #47
Hangin' out...
henryk8398's Avatar
The other advantage of manual steering is that you 86 a few pounds from the front, which is never a bad thing.
I have about $80 into this conversion, including the box. The new manual steering boxes I searched for ran anywhere from $269-569. Where did you get yours and how much did you pay?
I'll keep my money. That was the whole point of this thread. Besides the grand Cherokee steering box restores a lot of the road feel. It's no manual, but is a very good "sleeper" upgrade.
Rcdynamic88, why not start a thread with some information on what it takes to convert a PS car to manual and any potential SNAFUs you ran into? I'm sure it's pretty straightforward, but there's always some snag.
I'd love to read it!
Old April 1st, 2010, 07:05 PM
  #48
GM Enthusiast
OLD SKL 69's Avatar
Just finished up my conversion. It turned out great. Definitely has much tighter steering feel than the original box and much better response. I used the following parts:
used grand cherokee box w/shipping $40.00
81 Camaro high pressure hose 22.00
1ft of 3/8 rubber line for return hose 2.00
Lares #200 rag joint 34.00
3/8 x 8" brake line 2.00
Total investment $100
The camaro high pressure hose is metric and works perfectly with the steering box but will not hook up to the pump. I cut the end off of the high pressure line that connects to the pump and used one of the 3/8" nuts off of the brake line. I used a brake line flare tool to set the line up. You can go this route and not use the Lee adapters and make your upgrade look factory stock.
OLD SKL 69 is offline
Old April 1st, 2010, 07:53 PM
  #49
Car Junkie
Four Four Tony's Avatar
I used a 77-79 WS6 Trans Am steering box in my 442. It has 2 1/2 to 2 3/4 turns, takes my original hoses but did require the different rag joint. I didn't notice any difference in turning radius but the steering feel isn't stiff like a newer car it feels just like the original box in that respect. The chance of finding a good used one nowadys is slim so I bought mine rebuilt from Napa for $140 plus a $27 core charge.
I had a Grand National box in my 67 442 and while it felt great it did lose a lot of turning radius.
Four Four Tony is offline
Old April 1st, 2010, 07:58 PM
  #50
Grown Azz Kid
Olds luvr's Avatar
Four Four Tony, what did you do to use the GN box? My buddy has one for me that I am thinking of using in my 72.
Thanks,
Olds luvr is offline
Old April 1st, 2010, 08:03 PM
  #51
Car Junkie
It was a while ago so I'm going off memury but I believe I had to use a manual steering box rag joint which is the same as the one the Jeep box would take. The hoses have the Saginaw fittings on the box end so you have to use the adapters from Lee, Weatherhead or another PS supplier or you could cut the steel part of both lines, put male tube fittings on them, double flare and couple them with a brass fitting. I want to say the stock Pitman arm fits, and I think that was it.
Old April 1st, 2010, 08:15 PM
  #52
Grown Azz Kid
Olds luvr's Avatar
Thanks Tony....Sounds like no matter which box the rest of the process is pretty much the same
Old April 1st, 2010, 08:19 PM
  #53
Car Junkie
Yeah you're right. You could have your original or a spare rebuilt to close ratio with the stiff feel but it's like $325 bucks plus shipping. A lot of dough.
Old April 2nd, 2010, 04:50 AM
  #54
MN71W30's Avatar
Just ran across this thread, I plan on trying the conversion on my 65 Biscayne. My 71 442 seems to steer very nicely. The Biscayne is like a school bus.
Thanks for all the great info!!
MN71W30 is offline
Old April 2nd, 2010, 09:05 AM
  #55
Grown Azz Kid
Olds luvr's Avatar
Tony, thanks for the info. Would be nice to do the close ratio in the stock box but at 325 my pockets are telling me stick to the swap
Old April 2nd, 2010, 09:50 AM
  #56
Hangin' out...
henryk8398's Avatar
I also wanted the throw out there that a reputable rebuilder I spoke to said that unless he rebuilt both the PS box and pump, he would not warranty any work. I completely understand, but that further adds to the expense. Perhaps other rebuilders would warranty a rebuild on a box only, but I don't blame him for not wanting to.
Old April 2nd, 2010, 09:54 AM
  #57
Car Junkie
Henry is right. The guy I spoke to had a similar sentiment (might have been the same guy for that matter) so that's another $100+ on top of the box easily. It's a pricy commitment, worth it for sure but it's alot to drop at once. That's why I went to the TA box but the Jeep one sounds good too. From what I hear it gives you the stiff steering feel like a newer performance car.
Old April 2nd, 2010, 05:53 PM
  #58
GM Enthusiast
OLD SKL 69's Avatar
I know what you mean! My 67 Impala was the same way. I really like the conversion, and how it made the steering feel. The only problem is, now I want to upgrade the sway bars and bushings to take advantage of the better steering.
Old April 7th, 2010, 06:27 PM
  #59
GM Enthusiast
OLD SKL 69's Avatar
One interesting note about doing this conversion. I found that it was very straightforward and the only issue I ran into was the steering wheel alignment. The wheel ended up being off by a few degrees to the left and required me to adjust the tie rod sleeves. I have not heard of anyone else having this issue so I am not sure why I was so lucky. I confirmed it was a grand cherokee box by the pitman arm #'s but I could see the pitman arm alignment marks were different comparing the Cutlass one with the GC so I am assuming that's why it was a little off. No big deal, but just a good fyi in case anyone else has that problem.
Old April 7th, 2010, 09:35 PM
  #60
Hangin' out...
henryk8398's Avatar
Yeah, I had to play with the steering wheel. I have an aftermarket wheel, so it's adjustable. For those who have the stock wheel, could you explain how you got the steering wheel to center? I've heard of doing it yourself, but I don't know how it's done. Thanks!
Old April 10th, 2010, 06:15 PM
  #61
MN71W30's Avatar
Got it finished today. It made my old 65 Biscayne handle like a car 30 years newer. Awesome upgrade!!!
I bought a newer high pressure hose from a 80 Impala. I then cut and flared the fitting going into on my old pump. I used the piece I cut off for the low pressure stub coming out tof the box.
Thanks again to all the people who added to this thread.
MN71W30 is offline
Old April 11th, 2010, 07:01 PM
  #62
GM Enthusiast
OLD SKL 69's Avatar
Directions for centering steering wheel:
Loosen the tie rod adjuster tube clamps on both the left and right tie rods, then turn both tubes an equal number of turns in the same direction to bring the gear back on center. DO NOT turn the sleeves an unequal number of turns. If you closely follow this procedure you will not change your front toe setting. If you turn the tubes in one direction and the steering wheel position gets worse, start turning them in the opposite direction. Just make sure that you rotate them the same direction and the exact same number of turns.
Hope that helps.
Old October 26th, 2010, 06:08 PM
  #63
craftsman1956's Avatar
GC steering box
Originally Posted by henryk8398
Same here, I think I paid $60.00. I spent $15.00 on the Lee adapters and a new low pressure fitting (the original was beat up) and another $60.00 for the complete steering coupler, delivered. The Lee adapters just drop into the box fittings to convert the modern o-ring fittings to the flared fittings on pre-1980 cars. Even though the Grand Cherokee box has metric threads, they are close enough to work with the original fittings. I don't have any leaks from the fittings. I think the original A-Body steering box sweep is 40 degrees and the Grand Cherokee is 41 degrees. An awesome coincidence. I also found out about it on Chevelles.com, but found more specific information from the Pontiac Performance years forums. Lot of guys have done it to their GTOs. I am a big proponent of the swap. In my opinion, is the best "bang for the buck" after big sway bars to improve handling inexpensively. I'm amazed at how well the car responds. With the original box (I don't know what the ratio was 16:1?), sudden lane changes were scary. Not anymore! If you have any more questions, let me know.
What is the change?Will steering be tighter meaning less play and quicker response when turning?My 72 seems to require lots of work keeping the car going straight.
craftsman1956 is offline
Old October 27th, 2010, 05:44 AM
  #64
Lady72nRob71's Avatar
Yep!
I am liking the idea of this and plan to do it next year or so.
I was gonna have my original box rebuilt, but 450 is a lot of dough to drop when i can use the GC box for 150 or so...
Lady72nRob71 is offline
Old October 27th, 2010, 10:24 PM
  #65
svnt442's Avatar
Damn. I paid $237 to get mine rebuilt.
svnt442 is offline
Old October 28th, 2010, 05:15 AM
  #66
Where at?
I heard 325 for rebuild, about 25 in shipping, and another 100 to do the pump cause they would not warrant anything unless they do it all...
Old October 28th, 2010, 06:11 AM
  #67
Rickman48's Avatar
FYI - the Grand Cherokee was one of the vehicles on the 'Cash for Cars' list a while ago, and unless crushed, there's a lot of them out there!
Only thing they couldn't sell were the motors.
Prices on that box should be super cheap - shop the yards, and if you pull it yourself, even cheaper!
Rickman48 is offline
Old October 28th, 2010, 10:29 AM
  #68
svnt442's Avatar
This place. http://www.straightlinesteering.com/ They had it done in a day and they are local to me (2 miles from the house) so it was a quick turn around.
svnt442 is offline
Old October 29th, 2010, 06:30 AM
  #69
JS71SX
JS71SX's Avatar
The problem with a quick ratio gearbox is the stubshaft (part that connects to steering column shaft) is smaller. You can replace the rag joint when you replace gearbox. They are all saginaw boxes, anything from a camero/firefird or older vette will work; and yes you can o/h the box with a quick ratio set-up but that will most likey cost more than a new gearbox. Hope this helps.
JS71SX is offline
Old November 21st, 2010, 07:00 PM
  #70
69_supreme's Avatar
My 69 supreme has manual steering and it is a bear to drive.What all am i gonna need to get power steering on this beast?? My main concern is gonna be finding the correct brackets to mount the power steering pump.Any suggestions as to brackets that will work?
69_supreme is offline
Old November 22nd, 2010, 05:28 AM
  #71
bil
bil's Avatar
We never got the answer-will this work for the earlier cars,like 65? Thanks. ---bil
bil is offline
Old November 22nd, 2010, 05:43 AM
  #72
All 1968-1990 Olds V8 motors used essentially the same PS pump brackets (there are minor differences but they do not affect fitment), so any of those will be a donor. Be aware, however, that the pump pulley needs to match your crank pulley. Also be sure to get the two spacers that go between the block and the bracket.
joe_padavano is offline
Old November 22nd, 2010, 07:37 AM
  #73
69_supreme's Avatar
sweet thanks for the reply.If i decided to stick with the manual steering is there any type of box that would help steering like the grand cherokee box does for power steering??
Old January 4th, 2011, 04:53 PM
  #74
65Delta88's Avatar
Anybody know what size of socket I need to use on the rag joint on the steering box side? Nothing seems to fit........
65Delta88 is offline
Old March 15th, 2011, 06:14 PM
  #75
Stevec's Avatar
I saw that Lee has a power steering adapter kit. Is this everything needed to install the grand cherokee box? If not what else is needed? All this swap talk has got me thinking!
Stevec is offline
Old March 16th, 2011, 05:55 AM
  #76
AZ442's Avatar
Stevec
PM sent.
Good luck, don't start the car before all the air is out of the pump.
AZ442 is offline
Old July 21st, 2012, 06:51 AM
  #77
JimMorrisonFan67's Avatar
Ok can someone give me a complete lists of parts to buy to convert our 1972 cutlass steering box. The one we have now is so loosey goosey I am very uncomfortable driving it. This jeep conversion sounds like the thing we need to get this car under better control. Thanks
JimMorrisonFan67 is offline
Old July 21st, 2012, 07:33 AM
  #78
I know that we try to avoid references to other divisions here, but since there is already a very info-packed thread somewhere else, since, in some repscts, some GM cars from different divisions really are identical, and since I have still not gotten off my tuchas and written my own how-to on this, I would recommend reading through this thread for the detailed information you need.
MDchanic is offline
Old July 21st, 2012, 07:45 AM
  #79
Further information:
From a post of mine on that thread:
"The rag joint should be a Lares 202 (about $30 at Advance Auto) or a Dorman 31011 (about $75), if I recall. If you use the Lares, make sure you've got enough clearance to the casting for your socket to go completely over the 12-sided pinch bolt nut - if it's only part way on, you could think you tightened it when you didn't, with "exciting" results on the road."
Also, see this post and this one.
MDchanic is offline
Old July 23rd, 2012, 02:16 PM
  #80
Thanks for your help. Trying to get my husband to go for this. His new mechanic he has said the current steering box was working fine...I would like tighter more responsive steering..others have said it made their ride like a new car and thats what I would like..is it really true.
thanks
Quick Reply: steering box replacement.
