Proforged vs. Moog
Old November 24th, 2017, 11:45 AM
oldsonharmont's Avatar
Proforged vs. Moog
I'm finally resuming my '71 SX rebuild, and am looking at replacing upper/lower ball joints. Found both Moog and Proforged on Rock Auto and would like to know if there's any reason to spend the extra for Proforged? They claim their ball joints will correct the positive camber common to muscle cars of this era. Thoughts, opinions... thanks.
oldsonharmont is offline
Old November 24th, 2017, 12:53 PM
I used the regular Moog joints and my car seems to drive fine. I really don't know anything about their tall ball joints.
Fun71 is offline
Old November 24th, 2017, 01:15 PM
72 Olds CS
RetroRanger's Avatar
Here's a link.
https://www.rockauto.com/en/catalog/...ll+joint,10070
RetroRanger is offline
Old November 24th, 2017, 01:30 PM
Are you planning on running road courses? If not just run with the Moogs.
oldcutlass is online now
Old November 24th, 2017, 01:31 PM
A tall ball joint effectively changes the height of the spindle. This is the same reason why people use the B-body spindles on A-body cars - to fix the crappy camber curve and improve handling. Yes, this will make the car handle better, ASSUMING you properly set the alignment.
joe_padavano is online now
Old November 24th, 2017, 03:55 PM
Bernhard's Avatar
The drag racers also started using tall ball joints or a tall spindle.
One of the legends of the time increased the height of the stock spindle.
I always wondered if the tall ball joints or tall spindle would be safe on the street,as in cause the car to react unpredictably.Are the ball joints also low friction?
Bernhard is offline
Old November 24th, 2017, 04:38 PM
72 Olds CS
A tall ball joint effectively changes .......Yes, this will make the car handle better, ASSUMING you properly set the alignment.
Joe
How do the stock align settings differ from align settings w tall ball joints?
Old November 24th, 2017, 05:33 PM
Mr Nick's Avatar
Tall upper and lower ball joints are used very often in the "Pro-Touring" world, I have them myself. Usually need to get a different upper control arm as well. They are shorter than factory arms. With a taller ball joint and a stock upper control arm, you'll need quite a few shims to get the alignment right, and you may run out of room, especially if you're running headers. Which is why the aftermarket arms are shorter, so you don't need a ton a shims to pull the top of the tire in for proper alignment.
Also, assuming you're running modern tires along with the suspension upgrades, your alignment specs will change as well.
Mr Nick is offline
Old November 25th, 2017, 04:53 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
I like the sound of them, improved handling with a proper alignment and a 1/2" drop in ride height up front, which I could use. Something to consider.
olds 307 and 403 is online now
Old November 25th, 2017, 08:36 AM
Mr Nick's Avatar
New UCA with tall upper and lower ball joints:
http://scandc.com/new/node/37
Different options with only tall upper ball joints, and bushing type:
http://scandc.com/new/catalog/11?page=7
Plenty of ways to skin the cat...
https://www.bmrsuspension.com/?page=...100&superpro=0
Tall spindle with 2" drop, requires stock height ball joints and aftermarket UCA
http://www.ridetech.com/products/com...spindles-pair/
Mr Nick is offline
Old November 25th, 2017, 10:39 AM
young olds's Avatar
I have the proforged tall upper and lower in my 66 with stock arms and got a “pro touring” alignment with out any issues but I don’t have headers.
young olds is online now
Old November 26th, 2017, 12:30 PM
No plans for a pro-touring build, just a stock cruiser for local cruise nights and car shows. Great feedback though, and I'll probably stick with Moog and reuse my stock upper and lower control arms. The Proforged ball joints sound like they'll need aftermarket control arms to get the full benefit. As usual, thanks for all the helpful information.
Old November 27th, 2017, 07:15 PM
Mr Nick's Avatar
I agree with your decision. If you're vehicle is used for cruise nights, car shows, ice cream runs, etc... stick with quality factory style parts, and you'll be good to go!
Mr Nick is offline
Old November 27th, 2017, 08:19 PM
Bernhard's Avatar
I can't envision how tall upper ball joints effect clearance?
Bernhard is offline
Old November 28th, 2017, 05:16 AM
Changing the height of the spindle (which is effectively what tall ball joints do) requires the upper control arm pivot shaft to move inboard to achieve proper alignment. This usually results in clearance problems to the exhaust, especially on BBO cars with headers. Shortened upper control arms are available to fix this problem.
yeahbuddy
Suspension & Handling
December 25th, 2011 05:41 PM
charlierogers
December 21st, 2011 07:14 PM
RetroRanger
October 3rd, 2011 07:07 AM
JeremyTA
May 16th, 2011 06:29 PM
defiant1
April 16th, 2011 10:34 AM
Quick Reply: Proforged vs. Moog
