Front and Rear Control Arms
Old May 8th, 2019, 03:16 PM
Are the front upper and lower control arms the same on a 72 four door as the two doors? when searching for parts they never mention the four door models lol, same question on the rear upper and lower. I would like to get rid of the wheel hop on the car and I went ahead and ordered umi tubular kit for the rear and some new bilstein shocks. I don't think I can get tubular for the front due to the car having drum brakes. So the front will be re done with stock. Switching over to disc brakes isn't an option at the moment since I would like to get the suspension back in shape first due to the high costs of car parts in Canada lol..
Rear Control Arm Kit:
https://www.summitracing.com/int/par...01-b/overview/
Shocks:
https://www.summitracing.com/int/par...9294/overview/
Front Control Arms I think I need:
https://www.summitracing.com/int/par...0-pr/overview/
https://www.summitracing.com/int/par...6-pr/overview/
skyhigh is offline
Old May 8th, 2019, 04:42 PM
Yes. The only difference in the chassis among the 68-72 A-body cars is the wheelbase. Suspension is the same. Yes, some have oval bushings in the front LCAs and some have round, but the LCAs interchange among all A-body cars of those years.
joe_padavano is offline
Old May 8th, 2019, 07:03 PM
OEM disc or OEM drum...makes no difference in terms of control arms.
Aftermarket, thin-steel control arms with oval bushings on the lowers? I'd rather have the GM originals.
Schurkey is online now
Old May 9th, 2019, 04:05 AM
It matters from what i read...cant use tubular up front due to drum brakes...they wont fit..stock is only option for drum i think. Aftermarket tubular would be alot stronger than stock.
skyhigh is offline
Old May 9th, 2019, 06:21 AM
1968 442 Convertible
bry593's Avatar
If on a budget, don’t waste money on aftermarket control arms. Money better spent on moog bushings and springs and some kyb shocks. Will make your car ride like new.
Aftermarket control arms cost a lot for the good ones. The cheapos can cause fitment issues with springs, shocks, sways, improper geometry, low quality bushings, etc.
bry593 is offline
Old May 9th, 2019, 09:10 AM
I agree with you there, but i wouldn't be able to tie my friends hoist up. I'm pretty sure i couldn't do all that bushing work in a day lol..that rear control kit from umi wasn't cheap at all..pretty close to 700 Canadian after shipping and brokerage fees lol...200 for the shocks lol..and the bill for the front probably gonna be much more..i need to get my work done on the rear in a day so that why Im going new so i don't have to do all that bushing work.
skyhigh is offline
Old May 9th, 2019, 03:11 PM
If on a budget, donít waste money on aftermarket control arms. Money better spent on moog bushings and springs and some kyb shocks. Will make your car ride like new.
Believe it has been documented - Asian off shore arms with failed welds, and broken ball joints. Save your money or go with ones that can be proven to be North American manufactured.
newmexguy is offline
Old May 10th, 2019, 12:51 PM
i need to get my work done on the rear in a day so that why im going new so i dont have to do all that bushing work
You're going to remove and install the control arms no matter what.
Beyond the R&R time, installing Polyurethane bushings in the rear arms would be about a two-hour job, if you go into it with a fresh propane cylinder for your torch, and an adequate supply of emery cloth and Scotchbrite pads so you don't have to make a parts-run in the middle of the job.
"I" would be more likely to give the friend some cash for extra shop time, than to buy substandard parts to "make the job go quicker".
Old May 10th, 2019, 05:49 PM
bry593's Avatar
Sure are a lotta Canucks on this board.... Feels a bit like an episode of "Trailer Park Boys" meets "RoadKill", also known as "ColdWarMotors". Check out the ColdWarMotors vids on youtube. Great way to procrastinate working on your own car.
bry593 is offline
Old June 9th, 2019, 06:34 AM
It was a fight replacing the rear upper and lower control arms, 50 years of rust lol. It was the upper bolts that went through the frame causing headaches, had to use a sawzall for those using multiple blades lol. One of the two rear end housing bushings came out easy, shocks were the easiest to remove. I have a few things to do today before I'm done with the rear end but I need you help with the torque specs, I dint get install instructions with https://www.summitracing.com/int/par...01-b/overview/
from reading other posts here, I need to torque the bolts with the weight of the car on the ground, and I need your help with that please and thanks. When I bought the car it didn't have a manual to refer to the specs and I'm not sure that would even be the same with the tubular and urethane bushings..
skyhigh is offline
Old June 9th, 2019, 12:22 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Yes torque with the car on the ground, full weight on the chassis. Google...Look up the bolt diameter, grade, and thread count for torque.
droldsmorland is online now
Old June 9th, 2019, 02:11 PM
I I dint get install instructions with https://www.summitracing.com/int/par...01-b/overview/
Specs at Summit web page say that those arms have Polyurethane bushings.
There is NO need to torque them with the suspension at normal ride-height. Those bushings are not bonded to the shell and sleeve like rubber bushings.
If you had rubber bushings, you'd need to have the suspension at normal ride height before torquing.
Old June 10th, 2019, 09:15 AM
Thanks 4 that. At the moment im having a hard time getting that ring on the back of the bushing..the pumpkin is really tight on the drivers side..the bushing looks like its set all the way in..passanger side went on easy
skyhigh is offline
Old June 10th, 2019, 04:32 PM
classicmuscle.442's Avatar
Torch would speed things up considerably, heat the nuts red hot and usual they come right off.
classicmuscle.442 is offline
Old June 10th, 2019, 08:57 PM
Originally Posted by classicmuscle.442 View Post
Oxy-acetylene torch would speed things up considerably, heat the nuts red hot and usual they come right off.
FIFY. Propane and MAP-Pro would likely be a waste of time.
Old June 12th, 2019, 05:49 AM
The umi tubular upper and lowers are in, bilstein shocks and the sway bar..supper happy with the feel. Love the poly bushings and happy to say the wheel hop is gone..
skyhigh is offline
mbabs311
June 19th, 2019 05:51 PM
Dan A. Macal
March 9th, 2015 05:48 PM
brandon reynolds
December 10th, 2013 06:52 AM
197064buickspec
September 9th, 2013 09:17 PM
jpaulwhite
July 22nd, 2010 07:01 AM
Quick Reply: Front and Rear Control Arms
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
