Cutlass OEM Suspension Dimensions/Geometry
Old July 12th, 2013, 03:37 AM
e129745's Avatar
Am looking for any info on 1968 Cutlass front end suspension dimensions. I would like to compare stock geometry with after market upper A-arms and std vs taller upper ball-joints.
I know it takes considerable effort and ingenuity to get accurate results and was hoping someone would want to share what they have done. Maybe someone knows of factory published specs/drawings or similar, that would be good also, although I'd need ride height or arm angles for it to be helpful. I'll measure my track width to come up with scrub, but vertical joint and bushing dimensions and horizontal to chassis center line dimensions and angles are what I think I'm looking for. Instantaneous center and roll center is the info I want to take a look at.
I thought I'd find something for a late 60s Chevelle and call it good, but am not finding the right place to search, so why not ask for the best info at the best place? and here I am...
e129745 is offline
Old July 18th, 2013, 01:40 AM
Seff's Avatar
When you DO find it, plot it into this and save the results. http://www.vsusp.com
Seff is offline
Old July 18th, 2013, 02:48 AM
e129745's Avatar
Yes, I have found this tool as well and I agree, it looks very helpful. A change here or there and you can immediately see the results.
I do appreciate your response and help.
Patrick
e129745 is offline
servexcell
April 6th, 2015 02:56 PM
Sampson
August 2nd, 2014 10:26 AM
mat1227
September 13th, 2013 04:52 PM
tmaleck
June 11th, 2013 12:01 PM
hunter
Wheels and Tires
April 16th, 2012 06:17 PM
Quick Reply: Cutlass OEM Suspension Dimensions/Geometry
