Ball joint rubber boots
Hi
Is it possible to get replacement boots for the suspension ball joint somewhere ??
it would be nice, since my suspension parts are only a few years old. It would be a shame to replace them just because of a cracked boot :-(
thanks
thanks
There are many sources here in the US for the boots. PST has modern material boots in different colors. I think Inline Tube has replacement boots, also. The real problem is that today's rubber is different and not as durable. Here's a seller to get you started
https://pitstopusa.com/c-135002-susp...ust-boots.html
I have them at $ 5.00 each, if you need, and can stuff a bunch into a small padded Manila
envelope for $ 5.00 or F R E E pick up.
I used to have some really nice reinforced ones, but that company went out of business on me....
Always best to simply call me -- Craig -- 516 - 485 - 1935....
Also have Tie Rod Boots -- all 3 openings -- 1/2", 9/16", & 5/8"...
Thank you very much Mrolds69 and Craig. I do appriciate your help. I did not get any usefull hit when I did a search my self, but now I have something usefull to work with.. thanks.
I will get under the car in the nearby future and measure the sizes, and go from there.
4speed455
January 26th, 2019 03:48 PM
