Riding mower woes - 4 year old Snapper ST1842
Old March 13th, 2018, 10:18 AM
344879M363895
70-442-W30's Avatar
The lawn was long enough here to mow in February.
Went and got some fresh fuel for the riding mower and it started on the first turn of the key. Got it around the corner of the house and it cut out. Disengaged the blades and it started right up. Made it to the rear corner of the house and it quit again. This time nothing but a faint click.
So as some of you have much more experience in dealing with issues like this than I do, I'm wondering what's up.
If it was a solenoid, would it even have re-fired the first time it shut off? I did charge the battery after this happened and the click is just stronger when I turn the key now. I know it isn't fuel related because it just started right up before, and now it isn't even cranking. The battery cables were tight.
Got the solenoid on order just in case...good to have one as backup anyway if it isn't the problem. Won't get here till early next week. But aside from that this system is pretty simple, it does have a seat safety switch and I also don't think it will start with the blade engaged or without the brake pedal depressed.
Thoughts?
The manual with schematic is here in case anyone wants to take a look: https://www.snapper.com/na/en_us/sup...ted=2691183-00
70-442-W30 is offline
Old March 13th, 2018, 10:51 AM
m371961's Avatar
I would check the wire from solenoid to starter, clean and tight. If possible check volts at starter when trying to crank.
m371961 is offline
Old March 13th, 2018, 02:46 PM
same but different
don71's Avatar
I get only a couple of years out of lawn tractor batteries.. Maybe start there and rule that out.
don71 is offline
Old March 13th, 2018, 03:28 PM
therobski's Avatar
X2 Don71. I have a year old Gravely 54 XL zero turn and the battery failed in 2 years of ownership other than that, it's been a workhorse.
therobski is offline
Old March 13th, 2018, 03:29 PM
therobski's Avatar
A 4 year old Gravely!
Old March 13th, 2018, 05:05 PM
Lansing built
1970cs's Avatar
Turn the key on and take a big screw driver and cross from one post to the other. If it is the solenoid or the power wire to the solenoid it should roll over and start. You can check for twelve volts at the small start wire with all the safeties satisfied. If you have 12 volts present when the key is in the crank position then more than likely a bad solenoid.
Please as advised check grounds and make sure the battery is up.
Pat
1970cs is online now
Old March 13th, 2018, 07:00 PM
Rocketowner's Avatar
Was it in a warm enough place that the battery would not freeze.? If not I would take the battery out and have it checked. If the battery lost its charge,and it froze , that is probably the problem. Good luck, Larry
Rocketowner is offline
Old March 15th, 2018, 12:20 PM
344879M363895
70-442-W30's Avatar
Battery fully charged. Tested about 12.5V. Tested solonoid. Works. Tested cables. Fine. Starter itself fine.
Problem was engine was locked up. Not sure what exactly is going on. Starter had to be manually disengaged by turning back to rest position. However, I would need one of these too as it is cracked at the center and not even lined up where the keyhole...rotated around 90 degrees https://www.ebay.com/p/Briggs-Stratt...eel/1720335993
At this point, I'm not even messing with it. My yard has about doubled in size vs our previous place anyway and I will upgrade. Felt the 18.5HP was a little light for mulching here anyway. The entire engine is available for about $550 via Amazon if worse came to worse and add in the cost of the flywheel and I'm starting to get to the point where it may not be worth it.
Thanks for the ideas. It was fun to diagnose a little but I just don't have the time to get into it further.
Old March 15th, 2018, 01:52 PM
https://video.search.yahoo.com/searc...e8&action=view
Jamesbo is offline
Old March 16th, 2018, 11:24 AM
344879M363895
70-442-W30's Avatar
Just don't have the room in my garage for that one Jamebo. Nice machine though.
Old March 16th, 2018, 03:02 PM
Hookers under Hood
76olds's Avatar
Have room for a honda ? Be done quicker... get workin' on the Olds and drinkin' beers sooner !
Put-er-ther !
https://www.msn.com/en-ca/autos/news...zUM?li=AAggFp5
76olds is offline
Old March 16th, 2018, 05:08 PM
Lansing built
1970cs's Avatar
How much grass or acres? What's the budget?
Pat
Old March 19th, 2018, 08:22 AM
344879M363895
70-442-W30's Avatar
I ended up with a 22HP Husqvarna twin cylinder. A few inches larger cut, 46 vs 42. Has the same exact model hydrostatic drive in it that the Snapper has. Tuff Torq http://www.tufftorq.com/product/k46/ That costs about $500 or so to replace so now I have a spare if needed, plus the tires and wheels are the same size too. Starter and battery also. Starting to think like you guys...
Pat, I have about 3/4 of an acre here. This new one cost me about $1700 with tax delivered. That sweet sound of the twin cylinder sure beats the old one. Doesn't seem like much would bog that down at all, even if I end up putting a mulch kit on it.
Old March 19th, 2018, 08:24 AM
344879M363895
70-442-W30's Avatar
Put-er-ther !
That sure does look nice. Needs twin chutes to slow it down.
70-442-W30
June 14th, 2017 03:07 PM
boondocker
Non-Olds Engines
December 10th, 2011 06:06 AM
1969w3155
October 26th, 2011 12:47 PM
BIGJERR
February 20th, 2011 02:23 PM
z11375ss
August 31st, 2008 06:41 AM
Quick Reply: Riding mower woes - 4 year old Snapper ST1842
