need help with electronics (LEDs)
i love electronics but i need help with this one. it is dealing with LEDs, i need to figure out what resistor i need. i have
8 volts to supply the LED
the LED operates on 4 volts and requires .02 amps
how do i figure out what resistor i need?
i have googled LEDs but it keeps coming up with flashlights, i need to look longer maybe.
So you have to drop the other 4V across the LED. Since current is known and will be constant across the resistor also, apply Ohm's law - R=V/I
4/0.02=200 Ohm.
Now what wattage? P=E2/R or I*V.
0.02*4=0.08W.
4/0.02=200 Ohm.
0.02*4=0.08W.
