Lighting for pole barn
Old March 15th, 2017, 04:23 AM
  #41
Happy Trails's Avatar
Originally Posted by MDchanic
Happy Trails, what kinds of fixtures are you comparing?
The LED units I've used have drawn in the range of 1/8th to 1/10th the power for the same amount of light, compared with incandescents, and about half of the power compared to fluorescents.
Just curious why the efficiency levels you've got are so similar.
I compared the LED fixtures above to a basic tandem fluorescent fixture. Here's a link to one from Home Depot.
The LEDs above produce 14,700 lumens per fixture using 138.929 watts, which gives you 105.809 lumens per watt. Anything over 100 (at this point in time) is very good.
One 32 watt T8 fluorescent tube produce 2,875 lumens, which is 89.8 lumens per watt. Link to an example.
T5 fluorescent tubes are even more efficient than T8s. One 54 watt T5 produces 5,000 lumens, which is 92.59 lumens per watt, but the tubes are much more expensive. Link to an example.
LEDs are a little more efficient than fluorescent tubes, but the significantly higher price requires many years of electrical usage to pay off.
Happy Trails is offline
Old March 15th, 2017, 06:24 AM
  #42
T5 fluorescent tubes are even more efficient than T8s. One 54 watt T5 produces 5,000 lumens, which is 92.59 lumens per watt...
Ah. I've only ever had T-12s. I never realized that the T-8s and T-5s were so much more efficient.
This brings me back around to my initial advice:
Scrounge up some good used fluorescent fixtures to use for a few years, until the price of LEDs has come down more, and then buy LED fixtures, when the price won't break the bank.
MDchanic is offline
Old March 15th, 2017, 07:27 AM
  #43
Originally Posted by dream66
Here's a pic of my 40x60 section with 7 led fixtures at 12' - 13' height
Each fixture is 4 - 4' 18w LED tubes.
My calcs indicate 5 cents per hour to operate
What is this construction type called? I want a non-wooden building for fire prevention and to be able to stop a falling tree; this might be a solution.
Koda is online now
Old March 15th, 2017, 05:25 PM
  #44
zeeke's Avatar
May Have been an IAEI mag. I have a friend who reads both as well and he has a memory. I'll ask him and get back to you.
Originally Posted by Cincinnati Rick
Thanks for the info.
I read that mag all the time although I don't remember seeing that article. I have a stack of back issues in my office so I'll take a look tomorrow and see if I can find it.
zeeke is offline
Old March 15th, 2017, 05:43 PM
  #45
Cory
dream66's Avatar
It's a Mueller Kit - bolt up. http://www.muellerinc.com/
There are other manufacturers but since it was my first do it yourself metal building and since the distributor is close by I chose their kit
With one other inexperienced helper we erected the 40 x 105 frame in 8 days using a rented extending boom forklift and a scissor lift.
Here's a link to the build progress: http://s819.photobucket.com/user/Sho...?sort=2&page=1
The middle section with the windows and walk door is my 1200 sqft living area
dream66 is offline
Old March 15th, 2017, 07:51 PM
  #46
Interesting. Not sure if they'd come to lower Indiana, but maybe worth a call.
Nice barndominium.
Koda is online now
Old March 17th, 2017, 08:40 AM
  #47
Rustbucket2's Avatar
Rick, thank you for working that out . A big thanks to all that gave me there input, lots of options! Here is what I went with, ordered 6 to start, they are on there way. hope I made a good choice. again thanks to everyone. will post a picture after I get them hung.
http://www.primelights.com/LED-4-Lam...-4SRHBLD72.htm
Rustbucket2 is offline
Old March 17th, 2017, 08:42 AM
  #48
Cincinnati Rick's Avatar
What's the part number?
Cincinnati Rick is offline
Old March 17th, 2017, 08:59 AM
  #49
I have item # PL-4SRHBLD72
Old April 30th, 2017, 06:08 AM
  #50
Any updates on the lighting installation?
Old April 30th, 2017, 03:59 PM
  #51
Went with 10 lights. might put a few more in, but will see how this works for me, for now.
Old April 30th, 2017, 06:38 PM
  #52
RROLDSX's Avatar
Nice shop!
RROLDSX is offline
Old May 1st, 2017, 10:03 AM
  #53
Good call.
Are you planning on doing anything with the open ceiling?
Old May 1st, 2017, 03:28 PM
  #54
The contractor wanted 7200 to close it in. so I'm just going to have the inside roof spray foamed, that's 1700. But I have all summer for that.
Old May 1st, 2017, 05:52 PM
  #55
Ouch! I was just curious because a nice white ceiling would help the lighting levels a bit.
DewChugr
November 13th, 2014 11:32 AM
Lady72nRob71
July 1st, 2012 09:56 PM
Oldsguy
October 17th, 2010 05:55 PM
ctrain22
December 2nd, 2009 08:24 PM
aafuel
January 21st, 2009 07:12 AM
Quick Reply: Lighting for pole barn
