Found this funny...
Found this funny...
I quit buying the junk "safety" gas jugs because you end up spilling it everywhere. You can still order good metal cans from NAPA or somewhere like that but I get old ones from flea markets
That is hysterical!
I absolutely hate those things! I totally fail to see how spilling gas everywhere when you use them is supposed to make anything "safer!" Especially when I am using them filling the boat...over the water! I would love to discuss with the engineering genius that came up with these! I would be livid if they spilled over my cars' paint!
hey thats one of the good ones.the ones i hate are the ones with the lever you push down,but first you have to flip this little lock button before it pushes down.and i'm right handed so i have to reach over the top with my left to flip the button and push down with my right finger.THHHEEENNN.to try to tip the jug and still hold down the button you need to be a contorsionist.
That's good, I'm going to have to post it on my FB wall.
I wonder if there has been litigation because someone burst into flames while using one of the "safety" / "environmentally friendly" gas jugs.
I have one of the Eagle safety cans I ordered from Amazon. Hoping it is the last can I ever need to buy -quite an investment. But I just got tired of replacing those plastic cans every 2 years when they broke. Plus they rip you off bad for those too...
To answer the question you all seem to be asking, it wasn't a politician who came up with this nonsense, it was insurance companies. They set most of our regulations. They run the NFPA which over regulates everything to do with hazardous materials and electrical installations. This is a classic case of when to much protection makes the problem worse. The only way to not spill gas with these cans is to take the spout off and dump it without it. How much safer is that? At least it makes it less prone to spilling.
These could have been added to the "Things that don't work" thread... We have them at my workplace, and every time I have to use them, I say "these things don't work for sh$t!" I will cling to my old cans for as long as I can. After that I'll get creative and fabricate my own! #WORTHLESS!!!!
Most of what was done with these idiotic cans was in regards to vapor. Notice the got rid of the hole on the other side of the can so that air can get in while pouring? They had to redesign the filler neck so that air can get in while you pour, but not while it is being stored.
Isn't that just ever so special?
A guy at work drills a hole and puts a tire valve stem in the back. Takes the core out and uses the valve stem cap to open and close the vent. You have to use a lone wire or something to feed the stem into the hole through the normal spout.
That's what I was thinking. I used to travel out to CA frequently in the early 2000s, and that is where I first encountered those cans. The folks that lived out there told me that was the only kind of can you could buy in CA. Took a few years to make it to MN.
