Body mounts for 72 cutlass from Fusick
Old November 6th, 2015, 07:08 PM
Chris
Oldssupreme's Avatar
Hi. Does anyone have any insight to installing the body mounts on a 72 cutlass? I purchased from fusick, and there are several rubber mounts with a metal sleeve inserted. Two of these have a small opening in the sleeve and the others have a larger opening. The assembly manual gives a few different numbers for the top mounts but the kit i got doesn't seem to jive with these numbers. Also, should the #5 mounts be the rubber mounts with no metal sleeve? These are the ones that just sit on the frame.
Thanks!
Chris
Oldssupreme is offline
Old May 13th, 2017, 03:02 PM
Zr1bandit's Avatar
Did you ever get an answer on the different size holes in the metal inserts ???
Zr1bandit is offline
joesw31
May 31st, 2015 04:17 PM
70 Racer
May 31st, 2013 04:16 AM
1k442
February 19th, 2013 01:08 PM
Nasty455
March 20th, 2012 04:57 PM
flatoz
March 15th, 2009 02:03 PM
Quick Reply: Body mounts for 72 cutlass from Fusick
