FE2 option available on Cutlass Supremes?
Old October 9th, 2010, 08:35 PM
oldzy's Avatar
Just wondering if the FE2 option (rear boxed lower control arms, frame braces, rear sway bar, larger front sway bar?, etc.) was available as an option on the 1972 Cutlass Supreme. tx
oldzy is offline
Old October 9th, 2010, 08:53 PM
oldzy's Avatar
Is this correct for the FE2 option? If so, was the upper rear control arm any different than the standard one?
  • Heavy-Duty Front and Rear Springs
  • Heavy-Duty Front and Rear Stabilizer Bars
  • Heavy-Duty Front and Rear Shock Absorbers
  • Heavy-Duty Rear-Suspension Control Arms
  • Frame Braces
oldzy is offline
Old October 9th, 2010, 09:28 PM
vette442's Avatar
Yes it was. I've owned at least five '72 Supremes that had the boxed arms/sway bar, and three of those had build sheets and/or window stickers showing it as an option line item.
Terry
vette442 is offline
Old October 9th, 2010, 09:41 PM
oldzy's Avatar
Thx.
Do you recall if the rear upper control arms were any 'beefier' than stock ones?
oldzy is offline
Old October 10th, 2010, 04:26 AM
vette442's Avatar
Thx.
They are the same open upper arms that are used with non-boxed lower arms.
vette442 is offline
Hessbros2015
March 9th, 2016 05:55 PM
Oldssupreme
January 26th, 2013 06:48 PM
pcard
Suspension & Handling
May 14th, 2011 02:54 PM
joe_padavano
Tech Editor's Desk
21
July 13th, 2010 03:30 AM
mmurphy77
May 18th, 2010 09:40 PM
Quick Reply: FE2 option available on Cutlass Supremes?
