front shocks
Old May 7th, 2010, 11:01 PM
marshall-no's Avatar
Question front shocks
Got a broken shock on the front of my 70 cutlass convertible - there is NO WAY that shock is coming out of the bottom through the control arm - how do I get it out?
marshall-no is offline
Old May 8th, 2010, 03:53 AM
jensenracing77's Avatar
why will it not come out the bottom. if it will not come out the bottom, you will have to remove the springs.
jensenracing77 is offline
Old May 8th, 2010, 05:06 AM
The upper part of the shock is bigger in diameter than the hole - and there is a small spring around the shock itself.
Old May 8th, 2010, 05:27 AM
defiant1's Avatar
Are you saying that you removed the top nut and the bottom 2 bolts and the shock is bent so bad that it can't be removed through the control arm??
Sorry, I did not post my reply in time to see your response.
I am not familiar with that shock setup.
defiant1 is offline
Old May 8th, 2010, 05:57 AM
you will have to pull the front apart to take them out. with the ball joint out of the spindle it would be a good time to see if it needs ball joints. with it already apart it would not be hard to put them in.
Old May 8th, 2010, 06:22 AM
Lady72nRob71's Avatar
Sounds as if a unique aftermarket spring was installed. I think I picture it in my mind. In that case, one of the ball joints will need to be release (prolly lower), arm dropped and shock removed. If going through this trouble on both sides, might as well replace ball joints and buchings if they are in your budget...
Lady72nRob71 is offline
Old May 8th, 2010, 06:40 AM
A picture would help us understand. What you've described so far is unlike anything from the factory so it is some sort of unusual aftermarket or custom installation.
joe_padavano is offline
Old May 8th, 2010, 07:18 AM
Shizzy's Avatar
I'm assuming it is some kind of load leveler shock?
http://www.shockwarehouse.com/site/mon_loadlevel.cfm
is so, Im sure you are going to have to un do the spindle at the lower ball joint to get the spring and shock out if the body of the shock is bigger than the hole.
Shizzy is offline
CyberCholo
Suspension & Handling
April 12th, 2014 11:50 AM
jensenracing77
April 24th, 2012 03:00 PM
Limey
December 21st, 2010 02:55 PM
360scamp
November 23rd, 2010 11:55 AM
Leroy701
May 5th, 2010 06:01 AM
Quick Reply: front shocks
