Easiest way to raise rear 71 cutlass conv
Old April 16th, 2019, 12:10 PM
delta254's Avatar
Hey Guys looking for the easiest simplest and cost effective way to raise the rear of my Cutlass, I have some rim rubbing issues on the Passenger side and don't want to cut anything. Everything is stock looking to raise 1" to 2"? Rubs on the back rear of the inner fender.
delta254 is offline
Old April 16th, 2019, 12:35 PM
'72 Cutlass ragtop
70sgeek's Avatar
look up Moog 5415 springs - have them on my '72 ragtop with 245-60-R15 on 8" rims + 1" spacers (9" total width). no rub or clearance issues. may be an option for you as well.
70sgeek is offline
Old April 16th, 2019, 12:37 PM
delta254's Avatar
well look into it that thank you
delta254 is offline
Old April 16th, 2019, 12:58 PM
oldolds88's Avatar
we used to put 2x4 blocks between the coils when I was young and poor.
oldolds88 is offline
Old April 16th, 2019, 01:09 PM
delta254's Avatar
hahah!!!!!!
delta254 is offline
Old April 16th, 2019, 01:15 PM
What size tires and wheels do you have? The 70-72 Cutlass rear wheel wells are huge and can easily fit 295-50-15 tires with lots of clearance.
Fun71 is offline
Old April 16th, 2019, 01:22 PM
delta254's Avatar
22" X 10.5" I know that's part of the issue huge rims back there but I don't want air ride or coil over springs.
delta254 is offline
Old April 16th, 2019, 01:35 PM
MOTORHEAD
11971four4two's Avatar
coil spring spacers for between coil spring and axle housing
https://www.summitracing.com/search/...ring%20spacers
I have spacers on 2 of my cars
11971four4two is online now
Old April 16th, 2019, 01:48 PM
delta254's Avatar
Thumbs up
Oh wow exacly what IM looking for thank you sir
delta254 is offline
Old April 16th, 2019, 03:11 PM
72 Olds CS
RetroRanger's Avatar
https://www.ebay.com/sch/i.html?_fro...pacer&_sacat=0
you can get these any size you want i have a 1" spacer on my car
RetroRanger is offline
Old April 16th, 2019, 03:14 PM
delta254's Avatar
Thank you wil get this done ASAP thanks
delta254 is offline
shockrebuild
August 25th, 2017 06:01 AM
71Viking Blue
July 13th, 2013 07:21 AM
delta254
December 3rd, 2012 06:24 PM
thatguy32567
February 20th, 2009 06:58 AM
67htc
July 3rd, 2007 07:45 AM
Quick Reply: Easiest way to raise rear 71 cutlass conv
