Riding high in the rear
I think my Cutlass rides too high in the back. It was this way when I bought it. Some of my peers say it looks great, evokes that classic '60s stance. What's the opinion here?
What Ron said but initially I don't think it's too high in the back. An easy check is measure from the ground to the peak of the fender wheel opening, if it's more than 1-1.5" higher in the rear it tends to look to high in back ( assuming the front end "looks" normal).
also there are spacers that fit under the rear spring on the axle, many people use those to easily and quickly lift the rear a preset amount. Take a peek under your car w a good light and see if there is a spacer between the perch and spring that could be removed to change your height.
Leave it alone. Nice Cutlass. Perfect ride height. Stock, I always thought they were a little low in the *** and nose.
I like the way your tailpipes are tucked and not prominent. That's the way a Cutlass should look. I think I'm a little lower than you but still higher than stock for sure.
Did you buy your car off a guy in Gates New York?
Looks good to me, I might even jack the *** up a little more. But that is the look I always liked, rake the rear... What dealer in NJ did you get the vehilce? Future Classics? I grew up in NJ. Leave after I retired 3 years ago... Nice looking vehicle!
