change body mounts 65 conv.
Old January 25th, 2019, 04:20 AM
STLCRZY's Avatar
Is it possible to change body mounts on 65 442 conv. without to rise body to much ...like these guy
http://www.superchevy.com/how-to/cha...vrolet-malibu/
Rubber or poly ?
STLCRZY is offline
Old January 25th, 2019, 07:01 AM
boese1978's Avatar
Do mean doing it without a lift like that?
boese1978 is offline
Old January 25th, 2019, 08:09 AM
STLCRZY's Avatar
No.. I mean if it's possible to change the bushings without lift the body to much from the frame on 65 442 like that
STLCRZY is offline
Old January 25th, 2019, 08:59 AM
Yes, that's the way I did mine.
oldcutlass is offline
Old January 25th, 2019, 10:13 AM
STLCRZY's Avatar
Correct me if I'm wrong but I think if trans and carb is operating with cable I don't need to loose anything more than the body bushings ...?
STLCRZY is offline
Old January 25th, 2019, 01:59 PM
My car was on a lift and I used tower stands to raise the body. I left the core support alone when I did mine. You just have to remove the bolts, jack the rear of the body up and starting in the front, slip the rubber mounts and bolts in place. The lower the body and make sure its still in the correct position and then tighten the bolts.
Old January 28th, 2019, 05:55 AM
STLCRZY's Avatar
thanks ...let you know if i have further questions
STLCRZY is offline
stuart
January 27th, 2020 04:47 AM
Collegecutlass
March 4th, 2019 06:32 AM
bigdooly
March 20th, 2015 05:53 PM
Shradezz70S
February 19th, 2012 08:11 AM
65 starfire
February 7th, 2008 11:24 AM
Quick Reply: change body mounts 65 conv.
