Intermediate steering shaft seal
Old January 11th, 2019, 07:34 PM
yorkman's Avatar
While lifting my 70 Conv. body off the chassis, my intermediate steering shaft caught on the engine and pulled the shaft out of the swivel joint, tearing the rubber boot. I found a replacement boot, but like to ask how to install it. Do I take the lower shaft out of the upper shaft? There appears to be a roll or shear pin between them, should I push or drill it out? or can the seal be stretched over the swivel end? Thanks, Bob
yorkman is offline
Old January 11th, 2019, 08:19 PM
yorkman's Avatar
Never mind, as usual I found my answer with a search after posting the question. Apparently the swivel pin at the top must be pressed out to change the seal. I have a press so its no problem. Thanks anyway, Bob
yorkman is offline
501Paratrooper
Suspension & Handling
31
February 7th, 2019 11:30 AM
cdrod
16
February 26th, 2015 09:26 AM
dc2x4drvr
May 2nd, 2011 11:10 AM
lll442
November 24th, 2010 09:22 AM
dynamic88
August 28th, 2007 11:03 AM
Quick Reply: Intermediate steering shaft seal
