66 cutlass steering wheel wobble
Front end was all replaced 25 years ago, everything seems solid still, no play.
Car drives/handles as good as it always been. Everything fine till about 70 plus mph, wheel starts vibrating/shaking. if i let go of wheel its bad. Don't feel anything in seats/floorboard/dash. Literally just wheel at above 70. Since ive noticed this I
-checked front end
-balanced tires, new front wheel bearings
-replaced lower bearing in steer column, new rag joint coupler
Today i was shaking the wheel while friend looked under hood, alot of movement where column goes thru firewall. Took column out and noticed there is a rubber boot that goes thru firewall, seems ok, little dry rot. Probably original. But it seems like theres too much movement there. Anyone have any ideas? A source to replace that boot? Il post pics soon
-checked front end
