Rusted frame in one area 71 cov.
My great aunt bought this car new I'm the second owner . I was going to repaint pull the motor and replace seal and gaskets put it together and drive it , by the way this car was in a garage since 1990. Here my problem behind the front wheel in front of the door the frame has rust hole the size of a golf ball and I was looking for expert ideas . Thanks for any advice
Welcome. There is no easy answer. Either the frame needs new metal welded in or it needs to be completely replaced. This is not uncommon with the boxed convertible frames. If there is a hole in one place, there's a good chance other areas are nearly rusted through also. Sorry.
It would also help to know what type of "71 conv" we're talking about. Cutlass? Delta 88? Ninety Eight?
Yeh, that's not the hole I hoped you talked about. You may want to go along the frame poking with a sharp tool to see if there are more soft spots. What state are you in? There are frames out there if you need one.
car came from Ohio i'm in Texas and I have in my garage it looks like she had it under coated,
are there other frames beside olds frame that will work if I have go to a different frame chevy Pontiac?
If you can get it up on a lift and use that sharp tool, I think it's called an awl, all over under the car. Floors, frame,trunk floor, etc. before you get too far into it. Depends on your plans for it but it will be good to know how much rust there is.
Any A body convertible frame, Cutlass, Skylark, Chevelle, LeMans, from 1968-72 will interchange with yours. From looking at the pictures, I'd bet there are more holes to be found. I know of 2 convertible frames in or near Indianapolis that might work for you if you get to that point.
