on disc brakes..
Old May 18th, 2016, 04:36 AM
sortasane's Avatar
on disc brakes..
What do you call the shaft or assembly that the front wheel bearings and rotor mount to on a disc brake system?
sortasane is offline
Old May 18th, 2016, 04:39 AM
m371961's Avatar
Spindle
m371961 is offline
Old May 18th, 2016, 04:42 AM
sortasane's Avatar
That is what I thought, but every time I try to find one the wrong parts come up.
Old May 18th, 2016, 06:41 AM
On most Oldsmobiles that shaft is actually an integral part of the steering knuckle. Many people will use the term "spindle" to mean the whole knuckle, not just the shaft itself. Since it is not a separate part, that's probably not an issue. If your bearing surfaces are damaged due to a seized wheel bearing, you need to replace the entire knuckle. Tell us year and model and drum or disk brakes.
joe_padavano is offline
72allblackcoupe
April 6th, 2014 07:20 PM
1carsick
Brakes/Hydraulic Systems
23
October 2nd, 2012 05:50 PM
russell-t
April 30th, 2011 05:56 AM
<c. larson>
Cars Wanted
September 23rd, 2006 05:57 PM
Det313
June 22nd, 2006 04:16 PM
Quick Reply: on disc brakes..
