Front springs/ rear springs
Old May 14th, 2016, 07:51 PM
Gary M's Avatar
Any advise on spring compressors for 71-2 cutlass front and rear springs. I tried Local auto parts rental but it would not fit into bottom a- frame hole. Rear spring compressor is needed too. Thanks in advance.
Gary M is offline
Old May 14th, 2016, 08:16 PM
lemoldsnut's Avatar
You don't need a spring compressor for the rears and for the fronts it is a simple tool. Here is a link to one Summit sells and it can be bought at most parts stores.
Hope this helps
Larry
http://www.summitracing.com/parts/WM...54?seid=srese2
lemoldsnut is offline
Old May 14th, 2016, 08:22 PM
Gary M's Avatar
Rears don't need compressors?
I have a bare frame so it would be nice to not worry about disassembling the rear suspension. Thanks for the lead on the front.
Gary M is offline
Old May 15th, 2016, 06:34 AM
scrappie's Avatar
Interesting, Ive never heard of needing a compressor for the rear springs? I've replaced a few and just disconnect shocks and drop rear.
scrappie is offline
Old May 15th, 2016, 07:33 AM
All you have to do is unbolt the shocks and pull the rear axle down as far as it will go. Since all you have is a bare frame, you can't have torqued the control arm bolts yet, as that would be incorrect without the weight of the car on the suspension.
joe_padavano is offline
Old May 15th, 2016, 02:28 PM
Gary M's Avatar
Thanks for the help everyone. Rear end is out and ordering summit tool for front tonight. I'll have to make a note on the torque after weight of car info. Don't want to forget that.
Gary M is offline
Harmon
Suspension & Handling
June 6th, 2015 10:33 PM
bigjaythe1st
May 8th, 2012 05:45 PM
yankees
January 4th, 2012 09:25 PM
jpaulwhite
July 19th, 2010 01:15 PM
NAS Backyard
January 26th, 2009 12:04 PM
Quick Reply: Front springs/ rear springs
