66 cutlass front coil placement
I have a 66 Cutlass convertible. I just replaced all of the front suspension except the coils.Everything is tight but I have a rattle on the driver's side.Does the lower control arm have a certain place that the lower end of the spring should sit in? Any help would be appreciated.
Not on a 64-67! Both spring ends are the same (tangential). The end at the top fits into a seat, and there is an inspection hole in the frame pocket under the upper A arm. There also are holes in the lower arm's pocket and the bottom end should be between them, or depending on how an aftermarket spring is made, it can be just past them but still in the pocket. Some coils are up to 2" longer than an integral number of coils, some are a bit shorter than that.
I am going to go ahead and embarrass myself with this one. I did good on the front end. It sounded just like the front until I opened the driver's door. It was the driver side axle bearing. Replaced them and everything is great now except the egg on my face.
