'70 442 Rear Sway Bar Shims
Old April 1st, 2016, 05:35 PM
DRXOLDS's Avatar
Hello All,
Just put new rear lower control arms on. What is the need for the shims for the sway bar, if the sway bar fit's snug (and square) to the arms...what am I missing?
Seems like everyone thinks you need the shims... what is their purpose?
Please advise.
Thanks in Advance!
DRXOLDS
DRXOLDS is offline
Old April 1st, 2016, 06:45 PM
same but different
don71's Avatar
Its sounds like you don't need them.
I didn't need them on my 71. Like you, it was square and snug.
don71 is offline
Old April 1st, 2016, 07:13 PM
DRXOLDS's Avatar
Thanks for the confirmation on what I saw...when installing.
DRXOLDS
Last edited by DRXOLDS; April 1st, 2016 at 10:58 PM. Reason: remove excess spacings on post
DRXOLDS is offline
Old April 1st, 2016, 07:15 PM
DRXOLDS's Avatar
Nice
I am not glad added so may spaces to the response...sorry
DRXOLDS
DRXOLDS is offline
Old April 2nd, 2016, 05:23 AM
The shims are simply to take up manufacturing tolerances so that you don't preload the lower control arms sideways if there is too much of a gap. The thing with tolerances are that they can go high or low. Sometimes you get lucky and everything fits without shims. Sometimes you need a lot of shims.
joe_padavano is offline
Old April 2nd, 2016, 07:56 AM
DRXOLDS's Avatar
Know what U mean
Hey Joe,
Thanks for the input...today I deal in microns.
In the "Good Olds Days" we dealt in 1/32"'s (Is this a correct word or description) ?
I own a shop and was showing the guy's how to sharpen .04" (1mm) diameter drills with coolant thru holes...(Bosch Fuel Part's)
OBTW we go down to .02" with coolant thru solid carbide drill's also..
Can't even see what we did unless under 145-X's magnification....
When someone tells me it's close ....I have a tendency to question
So in closing the 1/32" shims are OK with ME !
Thank again as always,
DRXOLDS
DRXOLDS is offline
August 19th, 2012 05:19 AM
agtw31
March 19th, 2009 07:49 PM
Olds luvr
January 19th, 2009 06:35 AM
cola
March 15th, 2008 03:08 PM
Carleta
July 4th, 2006 11:44 AM
Quick Reply: '70 442 Rear Sway Bar Shims
