Removing upper control arm bushings on a 70 442
Old June 5th, 2016, 07:31 PM
Old Olds Fanatic
Anybody know of a source to get an equivalent tool to the Front upper control arm bushing remover. It was a kent moore J-9502-3. Or how did you remove the bushings and reinstall them. I have a press but am having trouble find a washer that I could cut to insert around the bar.
Thanks,
Ben
70 w-30 is offline
Old June 5th, 2016, 07:53 PM
Here's a link to a thread by a member. The 70 should be the same as 72.
https://classicoldsmobile.com/forums...tml#post291066
Allan R is online now
Old June 6th, 2016, 04:00 AM
I used the open end of a combination wrench that was a snug fit against the "bump" on the pivot rod on the UCA. It worked well for removal. I have a pic around somewhere and can dig it up if needed.
65Delta is offline
Old June 6th, 2016, 05:33 AM
Or just go to any chain auto parts store and "rent" one for free.
MDchanic is offline
Old June 6th, 2016, 06:44 AM
Phantom Phixer
Charlie Jones's Avatar
If you want the real thing , here's one;
http://www.ebay.com/itm/Kent-Moore-J...-/281725073197
Charlie Jones is offline
Old June 6th, 2016, 06:46 AM
The easy (albeit, messy) way is to just burn the rubber out with at torch and dent the remaining shell to loosen it. I use a deep socket to press the new bushings in. A piece of angle iron cut to fit between the legs of the control arm prevent crushing by the press.
joe_padavano is online now
Old June 6th, 2016, 06:58 AM
After wire brushing the sleeve and lubricating with light oil like WD40, I have removed them with a blunt tipped air chisel.
Run to Rund is offline
Old June 6th, 2016, 09:52 AM
Old Olds Fanatic
Thanks for all the techniques! That's what I like about this site, there is a wealth of experience and talent here!
70 w-30 is offline
Old June 6th, 2016, 12:27 PM
2 cautions:
Be sure to support the arms due to the fact that bend easily.
And, be sure the bushing starts strait - if it does not, you will damage it.
My442 is online now
Old June 6th, 2016, 12:28 PM
2 cautions:
When the old bushing lets go, it will make a loud "pop".
My442 is online now
Old June 6th, 2016, 01:04 PM
That is messy and smelly. What about using a 1/2" drill to remove the rubber? I did that with the bushings on the rear control arms and it worked like a charm. I saw this video about how to do it and it inspired me to try that. Works the same for control arm bushings.
Old June 6th, 2016, 01:08 PM
That will work also. Pretty much anything that removes the rubber to relieve the compression on the ID of the steel sleeve will work.
Old June 6th, 2016, 01:34 PM
I was surprised at how easy it was, following that video. Good thing I do have a 1/2" drill with variable speed. My bushing cases were pretty close to welded in there with rust around the outside edges. Took a bit (I mean a LOT) of persuasion even after denting in the casings.
Old June 8th, 2016, 08:21 PM
Photoshop God
https://youtu.be/UPXf1OR9Lnk
That's what I did, smaller than 1/2 tho.
DewChugr is online now
Speednut81
June 23rd, 2013 09:01 AM
mcutlass1969
August 2nd, 2010 11:27 AM
bigwillystyle
December 21st, 2009 10:05 AM
therobski
October 24th, 2009 01:54 PM
tiparosa
February 26th, 2007 10:43 PM
Quick Reply: Removing upper control arm bushings on a 70 442
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
