Removing 72 Cutlass A/C evap box?
Who has removed the whole engine side AC box WITHOUT pulling the hood, fender or engine?
I am pretty sure it can be done as long as the inner fender is removed...
I am mainly wondering if it will come out the top or through the wheelwell?
Since i have the front suspension off, this will be the time to pull it if it needs to come out through the wheelwell.
Any ideas?
I sense the lid on the can of worms becoming loose.........
Any ideas?
Hi Rob
Uh Oh... is this a "might as well" rearing it's head?
It's been a few years since I've pulled one, but I'm pretty sure you can pull it out through the wheel well. Especially if the suspension is out of the way. John
Main reason is that I am pretty sure the evap (or something in there) leaks freon - there is compressor oil dripping from that case. The air that blows through it stinks, so something may have died in there, also.
I plan to have the whole A/C system removed and restored next year, so if having the suspension off will help, then now is the time to do it.
I cannot pull fenders and hood by myself and there is no room in my tiny garage to even do it if I had help. Car is immobile now without wheels...
Now the CSM does not say to remove the hood or fenders. It says to remove the right "filler plate" which i assume is the plastic wheelwell. It makes no mention whether to pull the thing out through the wheelwell or through the top. Just looking to hear about someone's experience...
costpenn
December 23rd, 2014 10:24 AM
