Jack stand locations
Greetings gentlemen! I put my 67 CS Vert on jack stands. This is the first time I’ve done this to any car whatsoever and want to make sure I don’t kill myself. Here are pics of where they presently sit. I can see one is not making great contact and will adjust it for sure, but overall are they in the right place?
Thank you for your help! So the CSM shows 4 jack points roughly where I have them now. Kinda hard to put a stand where I was supposed to jack. Is it ok or conventional to jack under the front cross member and place the front stands and then jack under the rear diff and place them under the axle?
Just a couple pictures. One picture with seven jackstands when I was replacing the suspension - four under the frame, two holding the rear axle & one holding the propeller shaft. The other picture is just a normal day in the park w/ four jackstands whenever I raise the car. Whenever I do raise the car (whether working on the rear-end [only] or the front-end [only]), I like to have the car stabilized at level. Maybe overkill but that's how I like to work under a car.
EDIT: I should note the ONLY reason I have two jackstands under the rear axle is because I was changing the upper & lower control arms; so, the rear axle is not holding the weight of the car, it is only holding the rear axle in place while I change and maneuver the control arms and shocks.
Thanks Vintage! Your pics are very helpful. I’ll be doing (or attempting to do) suspension work and general clean up and de-rustifying, so the extra axle jacks were noted. Can you expand upon the need to have a stand under the propeller?
The jack stand under the propeller shaft is simply a safeguard. As I was moving the rear axle up & down to accommodate the removal of the old upper & lower control arms and the installation of new UCAs & LCAs & rear sway bar, I simply wanted to ensure if the rear axle slipped or I knocked it off a jackstand the propeller jackstand would help stabilize the propeller while it was still attached to the rear axle. Additionally, as the propeller shaft is still attached to the rear axle & I was lowering the rear axle, I didn't want the propeller to gain or less its "pitch" orientation while moving the axle up and down. Really, nothing more than a safeguard. You should note that when changing the rear UCAs and LCAs I was using a floor jack on one side or the other of the rear axle to get the right height for inserting the bolts for the UCAs & the LCAs during installation.
I would not put a jack stand under the propeller shaft (drive shaft). They are hollow and will get damaged easily. If you are doing rear suspension work your better off putting the jack stands under the frame in front of the rear tires. Depending on what suspension work your doing in front, you may want to put jack stands under the lower control arms.
Good points all the way around. I’ll keep an extra 2 stands under the rear axle, when feasible. And….keep the hydraulic jack just snug under the front cross member when practical as well. I got to spend some time under there today. Getting acquainted up close and personal.
I like jacking the rear up first and placing the jackstands under the axle tubes.
I feel like the stands cradle the tube better than the frame so you know it won’t move.
Just a personal preference.
-peter
-peter
Now that it’s up on the stands, I noticed that the passenger side door gap is massive. It wasn’t that way before. Did I screw up my car or should this fix itself when back on the ground?
It's likely fine. My car bends an astonishing amount depending upon where I put the jack stands. Too far off from the rear axle load points and the doors won't open. It was kinda scary the first time.
