inner fender well to rubber dust shield staple tool ?
anybody know where to get one? who makes em? part # ? how much? the tool used to attach staples to rubber dust shields through inner front fenderwells above upper control arms...
scottyb 530-919-5522 or email sbaldridge@eid.org
Last edited by sbFALL63; January 26th, 2012 at 04:43 PM. Reason: more clarification needed...
If your old staples are still in there and not rusted away, you can reuse them.
I did this and not one of them broke.
If this will not work, and you have patience you could find new staples that will go in the old holes in the plastic. Or drill out tiny holes to push in the new ones.
An auto trim shop might have a stapler and might do it for a small fee. I am betting the proper machine will not be cheap.
Of course if you plan to use it a lot it would be worth the investment...
Have you ever noticed that there is no real pattern to the way the staples were put in? That means you can't go wrong with putting new ones in. Mine are pretty rusty so I'm taking them out and using the replacements in the same holes.
No pattern at all. Sloppy in fact.
One of mine was only half in the plastic! And to keep it original looking, I reused it's half side!
Here is my adventure...
https://classicoldsmobile.com/forums...tml#post306296
I remember that. Only thing different on mine is I think I have 1/3 less staples holding the flaps in. I might drill some holes and put in some extras. Right now they are out behind the shed wrapped in 3 layers of tarps to keep them from getting UV or IR damage. Still need the oven cleaner treatment before they get buffed or plastic painted.
They were installed with a very large electrical stapler, with the seal being held in place while the machine operator moved the inner panel to the next staple location. The staples were actually a wire on a spool. The staplers were made by Bostitch in Orange NJ. The company still exists, but it isn't the same, nor are they still located in Orange. They manufactured every type of commercial stapler that you could conceive.
http://www.bostitch.com/default.asp?...YPE=STATICLEFT
Gee, now I'm wondering if one of the T- staplers would have enough grunt to get through. Sounds like time to go find some plastic and test my assortment of staplers....
I had to laugh when I read the first post.....
The staples GM used are the hardest and toughest I have ever encountered.
If you reuse them, I second the opinion of drilling holes in the plastic liners, then use a body hammer and dolly to fold them over.
Best done with the liners out of the car.
Not a fun job!
Not a fun job!
Take a look at the thumbnail I posted. That is an original inner liner. Note how 'symmetrical' the stapes are? Its completely random. I think the line workers must have had about 15 seconds or less to do this because even the other side looks different.
It looks like they took more care in doing mine - must not have been built on a Friday...
Unfortunately mine was. Build dates were Friday evening and Mon morning. IMO this just is an early indicator of how the auto workers created the need for quality controls that brought justification to introduce robots to assembly lines. Faster, uniformity, work full shift without breaks, don't have to pay them, can multi task without getting confused..
Both mine and Allan's are mounted on the tire side, just the way the factory did them on our cars. That does not mean to say ALL were made like that. If a new line guy did some wrong, I doubt they would waste the parts for such a minor mistake...
I think was might have caused the confusion is that Rob took his picture from the inside of the liner, and I took mine from the outside. It's all good though. Rob also added some rock guard to the inside of his liners (I think it was to hide the discoloration of the plastic?).
Thay originally had undercoat on them but 1/4 was missing. I recoated it to restore it to how I think it was before and to hide the discoloration.
Funkwagon455
February 9th, 2015 04:48 PM
davebw31
March 25th, 2011 06:55 AM
