front coil springs
Old September 4th, 2018, 11:06 AM
Rustbucket2's Avatar
front coil springs
How can I tell what springs I have under the front of my car? I know the PO changed them, but car rides to high. when I checked the front both springs are in there perch, but are bowed to the outside and almost hit the shocks!! I needed to change the upper and lower ball joints and that's when I noticed something wrong. springs are 16 1/2 " long and 4 3/4 " round and have 11 coils.
1970 Cutlass Supreme
Rustbucket2 is offline
Old September 4th, 2018, 12:34 PM
I wouldn't worry too much about identifying what they are. Determine how high you want the front to sit relative to the factory height per the CSM, then get springs to achieve that height.
Fun71 is offline
Old September 4th, 2018, 12:47 PM
Do you think cutting a coil or two out, may let them set straight in the perch, so shock is in middle of spring, and not so much to one side?
Old September 4th, 2018, 01:49 PM
The springs in your car are identical to the OEM ones in my 72 Cutlass S. If your car is sitting too high there's got to be some other reason. Did you have the control arms out and torque them back when the car was off the ground?
Allan R is online now
Old September 4th, 2018, 02:04 PM
The Po put all that back together. But I'm still scratching my head , why did he powder coat the frame, but not replace the upper, and lower ball joints! When I removed the spring ( only pass side right now). The upper and lower A-arms moved very freely, not tight at all, I will re-torque them, when I put it back together. I looked up what paper work the Po gave me, and the receipt for springs has Moog 5380 is this right?
Old September 4th, 2018, 02:59 PM
The catalog data I have archived shows Moog 5380 as the correct application for a 1970 Cutlass convertible, 455 engine (excluding 442), with AC.
Fun71 is offline
Old September 4th, 2018, 03:13 PM
My 70 has air, but 350, punched out .30 over. Would that make a different's ?
Old September 4th, 2018, 04:12 PM
Some, but probably not much. The real difference is in the various spring rates, load ratings, and installed heights.
If you want the front lower, decide how much lower then look for pics and/or measurements of cars with specific springs.
Here's my car with Moog 5536 front springs from the wheel and tire size sticky:
https://classicoldsmobile.com/forums...tml#post959241
Basically stock suspension with Moog 5536 front springs and PST "442" rear springs.
Old setup:
Front and rear 245-60-14 on factory 14x7 SSIII wheels.
New setup:
Front and rear 245-60-15 on factory 15x7 SSIII wheels.
Fun71 is offline
Old September 9th, 2018, 04:28 PM
I cut 1 coil out , of both front springs, now I like the ride height .
Old September 9th, 2018, 04:53 PM
Just a thought. Had you considered these springs might be HD (or have been sourced by the PO for a convertible instead of HT) and have a stiffer spring rate? If that's the case you might find the ride somewhat harsh even with the reduced ride height. If that's the case and it doesn't suit your liking, source out replacement springs of your choice. I like the selection at RA.
Old September 9th, 2018, 06:09 PM
Allen thanks for your responds . That is along my line of thinking, These where new springs, and the car was just to high, so I thought cut them down see how they work, if I didn't like the ride , I would buy the right ones. and if I did like the ride, I would save a little money! I figured I wasn't out anything if it works, just a little of my time.
Old September 9th, 2018, 06:44 PM
I agree that it's worth a shot. If it doesn't, look at the spring rates on the ones you're considering to make sure they will have the right compression for height and ride. Good luck, I hope it works out for you.
Old May 6th, 2019, 11:39 AM
I've been reading this thread and others and am experiencing a similar high ride height on my 69 Cutlass vert.
Looking in the CSM on page 3-18 fig 3-58 and 3-59 I'm look for ride height data for convertible and don't see it.
So what is the correct factory ride height for 69 Cutlass vert ?
Bitburger is offline
defiant1
March 18th, 2010 06:43 AM
john suder
November 2nd, 2009 01:21 PM
Flye
June 12th, 2009 01:21 PM
veltboy618
March 26th, 2009 08:27 PM
mcutlass1969
August 6th, 2006 03:47 AM
Quick Reply: front coil springs
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
