1967 Olds 442 somewhat modified
Old August 10th, 2018, 12:48 AM
Navy P-3 FE (Ret.)
67Olds442X2's Avatar
Original California car still with original plates. I've had this car since 1991 and haven't touch the body though it's needs a little work. No rust anywhere. Still has it's "3V" head lamps. The only original parts missing are the engine, air cleaner and console.
Motor is a 455 .030 over, stock crank, eagle rods and Probe pistons. Approx. 12 to 1 compression, been using Cam II fuel. Has Edelbrock heads, Edelbrock Air gap intake with 950 Holly Ultra carb. Harland sharp 1.7 to 1 rockers, comp cams 'push rods running a Lunati (30420512) solid cam: 252/261 @ .050,, .560/.560 lift (.595/.595 w/ rockers). LSA 110 and advertised duration 285/295. MSD ignition, Hooker Headers, 3 inch exhaust with thrush mufflers. Complete "right stuff" disc brake system and tubular "A" arms up front with QA shocks and tubular rear arms with ladder bars and QA1 shocks. Rear is an "O" type in which I installed post unit from supercars along with axles. Richmond 3.90 gears. I rebuilt the TH400 using a kit from hughes replacing clutches and bands. Has a 3000 stall hughes converter and it actually chirps the tires when it shifts.Has a killer stereo system with Infinity 61/2" up front and 6x9's in back. Also have two infinity 10" woofer s in the trunk. More pictures and video to come. Have to lash all the valves again since a solid cam I loosened everything up.
Have the original hood that has some damage, the original suspension and wheels with good tires. Hub caps are gone. Have "A.I.R" system also. Interior is all original except for carpet. All my olds parts will go with car, 455 virgin block, oil pans one toro etc.
Going to be asking $27,000.
Great Mills, Maryland.
Build link
https://classicoldsmobile.com/forums...t-rebuild.html
67Olds442X2 is offline
Old August 10th, 2018, 07:24 AM
72 Olds CS
RetroRanger's Avatar
Looks pretty tight GLWS
RetroRanger is offline
Old August 10th, 2018, 08:08 AM
Navy P-3 FE (Ret.)
Thanks. I will get better pictures and videos this weekend. It runs like a beast.
Old August 29th, 2018, 10:57 PM
Navy P-3 FE (Ret.)
As you can tell I'm behind on updated pictures etc. I decided to re-wire under the dash, trying to run all the wires for the gauges and the stereo and make it look good is hard. On the health side my 13 years with Parkinson's is literally kicking my butt and slowing things way down. There are nights when i overdose a little which keeps up all night and I spent time with the car.
Old August 30th, 2018, 09:01 PM
edzolz's Avatar
Why is there no 5V on the firewall plate? Was this a 442 clone?
edzolz is online now
Old September 1st, 2018, 07:13 AM
Navy P-3 FE (Ret.)
It was built in Fremont, CA. Not a clone.
Old September 2nd, 2018, 11:19 AM
As the man said, Fremont did not use the Fisher body accessory codes other Olds plants did, which is why there are those big numbers there.
This car is obviously a modified race car, and being sold as such. Many of the "is it really a 442" items are not there, due to the performance upgrades,
and I don't think an interested buyer would really focus on that.
Koda is online now
Old September 3rd, 2018, 12:50 AM
Navy P-3 FE (Ret.)
I would have kept the car stock if I had the numbers matching engine. It had a 330 in it with all the correct 442/400 parts on it. Crome air cleaner, correct carb, A.I.R system for a 400, one correct exhaust manifold. It had spiral shocks and even one rear spring had the paper with the part number which was heavy duty. Boxed lower rear control arms and sway bars. I have all the original suspension parts, original wheels, hood, Basically everything I removed. I did sell the shifter and console along with the chrome air cleaner.
Some more pictures.
Old May 6th, 2019, 12:06 AM
Navy P-3 FE (Ret.)
Not for sale anymore. It's torn apart again.
Old May 6th, 2019, 01:06 AM
Rocket Renegade!
Bummer.
Hope you're feeling okay.
BangScreech4-4-2 is offline
67CSConvert455
March 29th, 2024 07:00 PM
oldcutlass
October 20th, 2023 08:33 AM
71 OLDS
July 7th, 2020 04:56 PM
67Olds442X2
January 1st, 2019 11:43 PM
1970Olds442
August 19th, 2012 10:19 PM
Quick Reply: 1967 Olds 442 somewhat modified
