1981 cutlass w/ built 455 runs 10-11 sec quarter mile 15 k invested!!!
another posting 4 a friend....... Way over 15k invested in Completley rebuilt, built,455 out of a 1970 oldsmobile cutlass supreme all receipts/ build sheet/dyno sheet with 10.5/1 compression, thats right 10.5 to 1 on a 455, Bored 30 over, 600 hp on the Dyno on high octane pump gas., all the race mods needed and too much to list in the motor, including balanced and blueprinted rotating assembly, roller rockers, match ported heads with stainless valves, guides and high temp seals, Have all receipts and time slips as well as Dyno sheet. The way this is set up it never has seen its 6800 red line capability. Rev limiter is set at 5800 so you can never blow the motor. 5800 is all it needs and that makes it super reliable too...Turbo 400, 3 speed transmission with b+m shift kit, 3500 stall, hurst ratchet shifter, custom aluminum drive shaft, Posi lock 410 gears in the rear and Traction bars put the power to the Mickey Thompson 235/60/15's street slicks. New bfg 235/70/14s up front. This thing hooks and goes. You can only smoke the tires if you drag the brakes.Holly double pumper on a high rise manifold with a Carter 90 psi electric fuel pump with a huge side mount fuel filter. Plugs have a perfect tan/grey burn. 150 psi on all 8 Cylinders. High performance grp rods, cp pistons, performance rings, v race mains, full roller rocker balanced rotating assembly. All receipts available.3" aluminum over steel duel exhaust from the 2-1/2 inch tube headers all the way back. WOW, you should here how this thing sounds. Awesome...Huge Be cool high flow radiator with duel electric fans and high flow water pump so its never hot.Interior is all done, exterior is fresh deep green metal flake paint, no rust, a couple scratches and the hood needs redone where the 4 inch scoop was attached, my body guy said about 500 to make it right, motor is done with new water pump, altenator, belts and hoses. Custom dash insert with top of the line Auto Meter Gauges. New bilstein shocks. More than 15k invested. Must sell. . Again this cars mechanical and interiors done. 0-60 in 4. I've only ran her twice at Bandamere. I'm no pro. I've been told she will do 10's with the right person behind the wheel.Add nitro and it will be in the 9's. Must see and go for a ride to appreciate....... i ahve only 2 pix but dont know how to post them please email me 4 price and pix tech9twista@yahoo.com thanx and have a good day
Guest
Posts: n/a
O My ******* GOD!
Bro this **** is pimp i hope it went to the right owner... I've got a 81 cutlass supreme up in Seattle. Any advice you could give me. Its stock. Needs new motor (rods shot) given to me by my dad. On tight budget but I'ma save your specks... lol...
1love,
.read:.
bone.dogs@gmail.com
1love,
.read:.
bone.dogs@gmail.com
lol yeah its not my ride but im sellin it for a friend he went all out on it....... and the crazy thing is i still havent sold it lol .... o well but yeah if i had like 10 grand to drop id bye this car...... well good luck with your project.... this is a good site for info.... anyways g2g ttyl
JerseyHarold
June 15th, 2015 03:01 PM
vistacruiser1971
October 8th, 2012 05:05 PM
TECH9TWISTA
January 30th, 2007 02:04 PM
