Care and Appearance Washing, waxing, paint care products, etc.
Cleaning engine bay
Old May 2nd, 2012, 12:56 PM
72CUTTY's Avatar
Cleaning engine bay
I need some advice. I want to clean my engine bay, besides the air filter and distributor, what other parts should i cover up? anything on the firewall? Im going to use a degreaser and will be going to the car wash
72CUTTY is offline
Old May 2nd, 2012, 01:25 PM
frankr442's Avatar
If you have an external regulator on the firewall, cover it, basically anything electrical. Also avoid high pressure spray at any gasket seam (valve covers, front cover, fuel pump etc.)
frankr442 is offline
Old May 2nd, 2012, 01:59 PM
72CUTTY's Avatar
thanks frank! i think im just gonna wipe the firewall clean and not actually spray water on it then..
72CUTTY is offline
Old May 2nd, 2012, 02:38 PM
Redog's Avatar
Leave the engine running
Redog is offline
Old May 2nd, 2012, 02:55 PM
*ssholes Garage
Seriousfun's Avatar
Great tip! And that way if you get something wet you shouldnt have, you will remember what you were squirting just before the engine died so the next time you'll know not to get that thing wet again.
Seriousfun is offline
Old June 6th, 2014, 06:27 AM
Gipper's Avatar
And wear a mask and snorkel!!!
Brian
Gipper is offline
JpMotorsports
March 31st, 2016 07:17 AM
joepenoso
June 4th, 2014 01:56 PM
Kidcutty
January 15th, 2010 10:36 AM
projectheaven
April 24th, 2008 04:19 AM
elmo
September 23rd, 2007 02:49 PM
Quick Reply: Cleaning engine bay
