Care and Appearance Washing, waxing, paint care products, etc.
71 window felt chrome
Old November 21st, 2017, 12:04 PM
1971 cutlasssupreme's Avatar
So I have the car apart for paint and decided to give the bright work some time on the buffing wheel. I hit the piece that goes along the top of the door with the sisal wheel to get some scratches worked out, and notice what looked like some kind of clear coat coming off. Since these have never been off the car my question is, did GM put some kind of clear on those pieces or?? Trying to decide a way forward since the "clear coat" doesn't seem to come off very easy.
1971 cutlasssupreme is offline
Old November 21st, 2017, 02:44 PM
My442's Avatar
Are you referring to the B85 Belt Line molding that the outer window sweeps attach to?
They are anodized aluminum, not stainless steel.
Two choices:
1. Have them stripped and re-anodized
-or-
2. Have them stripped and polished (which will need to be done occasionally)
My442 is offline
Old November 22nd, 2017, 06:38 AM
so any suggestions on how or where to send for re-anodizing? Can this be done at home with a kit from Eastwoods or someone similar?
Old November 22nd, 2017, 08:29 AM
Anodizing is an electrochemical process. You aren't going to do it at home. If you Google aluminum trim anodizing, you will find vendors. Don't expect it to be cheap.
joe_padavano is offline
Old November 22nd, 2017, 10:43 AM
RROLDSX's Avatar
I think Fusick’s still sells repro’s.
RROLDSX is offline
Old November 22nd, 2017, 10:51 AM
P/N CK70SR. Unfortunately, per their website, it's just the rubber, not the anodized molding:
This kit supplies the sweepers only for cars with the molding option.
Old November 22nd, 2017, 06:37 PM
thanks folks! I have found a couple anodizing companies locally, I'll contact after the holiday and see what the damage is going to be!
Old February 28th, 2018, 11:16 AM
Been a while, but had the anodizing removed and a company in OKC chrome plated them for me. They look really good! Wasn't cheap but neither is replacement pieces!
Old June 6th, 2018, 07:28 PM
Townie's Avatar
Hi do you have any pictures of them chromed?
Townie is offline
vagent
December 7th, 2010 03:00 PM
cutlasssupreme71
Body work
February 14th, 2010 10:12 AM
68Tom
May 21st, 2009 12:20 PM
jackedolds
16
February 7th, 2009 05:39 AM
rocketmann
January 6th, 2008 07:55 PM
Quick Reply: 71 window felt chrome
