My Scarebird Disc Brakes
Thanks for adding those photos . You know some of us have no idea how to make things work on these earlier models. We're all ways learning.
Show us a link to what else you've been doing with your ride. I've probably seen it, but others might not.
Good looking job. Did you use the Scarebird #OLD kit? I posted elsewhere about possibly using that on a 63 Starfire:
https://classicoldsmobile.com/forums...onversion.html
Did everything bolt up and fit right? Did you have any trouble finding the parts recommended on their list?
Can you list a source and part number for the master cylinder and proportioning valve? Did you use your booster or did you replace with a new style?
Thanks for any help you can provide.
Yes it was the OLD Number 61-64 The only problem I ran into was I powder coated my spindles and had to remove some powder coating wher it bolts at the top. I purchased all the parts at Rock Auto real easy.
Booster is a 67 Olds for disc/ drum
The master was purchased on eBay: http://www.ebay.com/itm/4-PORT-CORVE...8ff88a&vxp=mtr
Thanks, very helpful. Where did you find that booster?
I'm thinking of adding this to my 62 super wagon, will crager 31 spoke 15 inch rims fit over?
The set up looks good on your car, how is the stopping power in relation to the drums?
Steve
Steve
I can't answer that yet it is still winter here and haven't taken out yet.
We are under a weather advisory now for freezing rain and flooding as the snow is melting fast.
COME ON SPRING!!!!
I need to get my 98 out and clean the cob webs of winter out of her and go get a burger.
lets hope this is the beginning of spring, been a long cold winter up here.
COME ON SPRING!!!!
Finally got the car out of the garage to test the brakes and the brakes stop quite a bit better than before. Very happy I spent the money to do this.
Distribution Block
russell-t
Brakes/Hydraulic Systems
April 30th, 2011 05:56 AM
66ninetyeightls
April 20th, 2010 07:54 AM
