Brake lines leaking at calipers
Old September 25th, 2012, 07:09 PM
805cut's Avatar
I can not for the life of me, get these brake lines to stop leaking.. Not the hard lines i just put intoday but the soft rubber lines that run to the front caliper. Its leaking on the caliper side.. Any sugestions? Seems to be coming from From between the caliper and copper washer ive had it snug and it leaked now its tight and still leaking
805cut is offline
Old September 26th, 2012, 05:57 AM
Lansing built
1970cs's Avatar
I am sure that you replaced the sealing washers, also check for pitting at sealing surfaces or debirs. Also could be the banjo bolt it self has small crack in it?
Pat
1970cs is offline
Old September 26th, 2012, 08:57 AM
805cut's Avatar
Pat
Got some copper crush washers this morning. Hopeing it takes care of this issue cause its a pain in arsh!
805cut is offline
Old September 26th, 2012, 09:06 AM
Are you reusing the original banjo bolts or using new ones. If new, verify that the length is correct. I've had some that were just slightly long.
joe_padavano is online now
Old September 26th, 2012, 04:27 PM
805cut's Avatar
I bought and just converted the front to disc brakes, the kit came with two sets of banjo bolts. One set with the caliper and the other set with the braided front brake lines, the ones that came with the calipers are larger then the ones that came with the brake lines. Ive used both, with new washers and it still leaks.
Ive replaced the crsush washers and now the things still leaking! And with no pressure behind it to, everything seems str8 and seated.. Im going to loosen then re tighten everything. Im getting a bit hopeless here..
805cut is offline
Old September 26th, 2012, 06:08 PM
XCELERATIONRULES!
Nasty455's Avatar
Re using the crush washers is not going to work.
Try torquing them lightly.
They just need to seal any imperfections in the mating surfaces.
What type of fluid are you using?
Dot 5 or mixing fluids is a bad idea.
Nasty455 is offline
Old September 26th, 2012, 07:41 PM
805cut's Avatar
Im using dot 3, i was looking at some extra brake parts i had, found a pair of banjo bolts.. Actually took the tires off so i could get in there and see what was going on, they seem to be good as well as all the other hard lines that were leaking b4, just made sure everything was str8 while turning them tight.
All is well now, but to be honnest im scared to put pressure in the lines.. I will have a melt down if there still leaking!!
805cut is offline
Old September 26th, 2012, 07:48 PM
Tom442's Avatar
Silly question...but you did put a copper washer on either side of the banjo bolts right?
Tom442 is offline
Old September 26th, 2012, 08:26 PM
805cut's Avatar
Yes sir, things seem to be holding up at the momment.. Hopefully this things done with its drama!
805cut is offline
Old September 26th, 2012, 08:32 PM
I know you might have the problem sort of solved for now. Here's a thought though. Did you by any chance put the brass part of the hose onto the caliper backwards? (as in wrong side?) One side of the brass is completely flat to allow the seal with crush washers - new or old. The other side has a slight bevel. Even if you get washers in there, it will leak. Go ahead, ask how I know this....
Allan R is offline
Old September 26th, 2012, 09:26 PM
805cut's Avatar
Not even, there still leaking.. So your saying thwt the ring the banjo gose thru on the end of the brake line might have to be flipped over?
Haha and how do you know?
805cut is offline
Old September 26th, 2012, 10:30 PM
805cut's Avatar
Im going crazy, the brake kit came with "upgraded" front steel braided brake lines..oh la la I think there cheap. In the morning im going to get some regular rubber ones. Im done with these things..
805cut is offline
Old September 27th, 2012, 10:52 AM
Very possible. Have a look at this pic that shows the brake hose where the banjo bolt goes. One side is completely flat (caliper side) and the other has a shoulder (outer side). You will still need crush washers to seal the contact areas.
Kind of awkward to get this shot but here it is hooked up on my r.f. caliper
Oh, I found this out the hard way a few years ago when I did the front brake hoses on my 98. Lesson learned and shared.
Allan R is offline
Old September 27th, 2012, 11:53 AM
805cut's Avatar
Allan, thank you for the picture. Ive replaced these POS braided lines and put in regular rubber lines, seems to be holding up.. I think they were Just crap
805cut is offline
Old September 27th, 2012, 06:30 PM
Glad you are back in business!
Allan R is offline
brown7373
May 28th, 2014 08:08 AM
Oldssupreme
February 21st, 2013 10:24 AM
Fear Reborn
December 5th, 2012 05:23 PM
oldzy
Brakes/Hydraulic Systems
January 8th, 2011 06:05 PM
wired
January 30th, 2009 02:18 PM
Quick Reply: Brake lines leaking at calipers
