Anyone have original front disc brake calipers?
Just wondering if anyone has original front disc brake calipers? I have never seen any. Do they have the part #'s stamped on them? Same quality as the single piston reman stuff today?
What about the Master Cylinder? Same q's as above. thx
I think I would like to get a pair for my 72 Supreme if I can find any, have them rebuilt, etc.
You know I never thought about that when I put a set of remans on a few years ago,Probley should of kept them instead of turning them back in for a core........They are probley on some Chevelle by now,My bad!................Jerr
Ken, I don't know if these are original but here's what came off the 1971 spindles. One is date coded 92 and the other 113. Maybe someone can verify if these numbers would be correct for your 1972 or not. John
The part # for a Cutlass caliper and a Chevelle are the same number 5472161 thus if you go to your local parts store and buy reman calipers they will be original except fot the date code. Semi-loaded about $22CDN + core.
I'm pretty sure those calipers that John pictured are the factory originals, 5473497-L and 5473498-R.
Oldssupreme
February 21st, 2013 10:24 AM
jhoppeolds
Brakes/Hydraulic Systems
October 13th, 2010 06:22 AM
