Disc brakes: Front & Rear or either/or
Debating on benefits of front & rear disc brakes or better of the two for one of my cutlasses ('71) I look to upgrade wheels for as well. Same inquiry on the front & rear sways.
Any thoughts from experience out here
yaa...i am deff going to put a rear sway
and yaa i saved some money by not having to buy the rear discs too and im happy i did because like i said its stops really well....later on down the road once the car is finished then mayb ill throw some rear discs for appearance ...lol
master power has a set up with disk front and 11" rear drums have heard good things on it some of the rear end companies are doing the same thing instead of the high drag disk cheaper and you dont have to mess with the master cylinder or proportioning valve
Really all depends on what you want and how far you want to go. You could go all the way to 13 inch rotors and 4 pot calipers. Or just a mild update using parts off another car. Same goes for swaybars. In the end how do you want your car to look, brake, and handle. Only you can answer that question.
jpc647
July 1st, 2014 02:15 PM
Sestius
15
July 22nd, 2012 11:18 AM
2blu442
April 25th, 2011 06:52 PM
Kidcutty
Brakes/Hydraulic Systems
January 25th, 2010 07:05 AM
