Going Hydroboost on the 69 442
Old December 16th, 2018, 11:56 AM
Big Dawg's Avatar
Okay so I have decided to go Hydroboost on my 69 442. The brakes just were not performing to my liking. The cam in the 468 olds just isn't creating enough vacuum for the brake booster. Can not even make the brakes lock up and the pedal is so soft, even after bleeding the entire system 3 times.
I got my hands on a hydroboost setup out of a 95 astro van, my question is does anyone know off hand what the fitting sizes are on the power steering pump and the gear box?
Thanks again guys!
Big Dawg is offline
Old December 16th, 2018, 12:09 PM
First of all, if the pedal is soft, the booster is not your problem. A lack of boost will give you a rock hard pedal that won't move. Bleed the rest of the air out of the system before spending any money on new parts.
joe_padavano is offline
Old December 16th, 2018, 03:01 PM
classicmuscle442's Avatar
This^^^, soft pedal means you still have air in system. If you still have the old rubber lines that could be the problem. Just posted a thread with pictures of the old restricted hoses.
classicmuscle442 is offline
Bfg
August 22nd, 2019 08:33 AM
Mark71
Brakes/Hydraulic Systems
23
July 25th, 2016 12:45 PM
Rocketbrian
November 30th, 2015 04:02 PM
willj
April 27th, 2014 03:15 PM
scrappie
September 18th, 2012 07:54 AM
Quick Reply: Going Hydroboost on the 69 442
