Help naming part and parking brake ratcheting issue
What’s the name of that flying saucer looking spring backing plate that goes on the upper pin in drum brakes? (72 cutlass convertible) and anyone know where I can get a replacement? (Lost one 😩 -on a separate note - my parking brake doesn’t ratchet - if I step on it it will stop the brakes but it won’t click to hold them - any ideas? Thanks in advande gang! - Joe R.
Which it is - it guides the upper end of the shoes back into position against that pin when you release the brakes.
On the parking brake, are you saying that the parking brake pedal doesn't stay in the depressed position? If so, either the release handle is stuck in the pulled out position or the pawl that ratchets against the pedal arm is stuck (check for rust on the pivot pin) or the spring on that pawl is broken.
nobody has it - not napa - not advanced auto parts - not o’rileys - not aci auto parts warehouse - tried a local speed shop and nope - tried a brake and muffler business nope - had it been any single other piece ... no problem / it would be part of a kit - but not this
Well the weather has gotten nicer and back to work on the Olds - the parking brake cable Adjusted nicely - car keeps on surprising me how good of shape it is in with little rust - the issue with parking brakes is the ratcheting foot pedal - if I kick the release handle and twist the whole assemble left or right I can kinda get it to hold but the slightest bump will release it - is this something that I can clean up and make work nicely or should I just replace it?
Dylan Conaway
Brakes/Hydraulic Systems
January 14th, 2017 12:41 PM
Kilmster
August 6th, 2014 05:41 PM
