Brake conversion
Brake conversion
Slowly moving forward and I want to run the brake and fuel lines before the body goes onto the frame. I am converting from manual drums to 4 wheel power discs. I have the booster, master cylinder and prop valve for the swap. I will run new lines from the MC/Prop valve to a new split distribution block. Are the stock brake lines the right size or do I need a different size?
