booster/master cylinder 72 delta 88
Old September 1st, 2018, 12:43 PM
Fastmax32168's Avatar
I am trying to replace the master cylinder and booster on my 72 Delta 88 convertible. From what I have determined there was both a 9" bendix booster and a delco booster. It seems there was also an 11" booster. The 9" bendix booster being black, and the 9" delco gold anodized. It also appears there were several variation of master cylinders available. Thus far I have been unable to find the 9" Bendix, which is what I believe I have. Are they interchangeable? Can anyone help sort this out? Thanks, Roy
Fastmax32168 is offline
Old September 1st, 2018, 01:24 PM
MOTORHEAD
11971four4two's Avatar
There are places that rebuild power brake boosters
master cylinders any more that is what I am going to do
rock auto will have inexpensive brake parts If you are OK with that
There are many places that sell new bolt on kits for olds cars
11971four4two is offline
Old September 1st, 2018, 01:26 PM
I found what I need, as long as it actually shows up when I order it. LOL
Roy
Old September 1st, 2018, 01:34 PM
MOTORHEAD
All the best there! CHEERS
When I was into Toronado and other hard to find models
Brake place had it in stock... Good Olds days
https://brakeandequipment.com/
Kensey
September 14th, 2018 04:53 AM
geoff442
February 15th, 2016 02:53 PM
Lively72 olds cutlass 442
May 7th, 2015 07:52 PM
bluecab
Brakes/Hydraulic Systems
April 15th, 2015 05:27 AM
STLCRZY
March 10th, 2014 07:36 AM
Quick Reply: booster/master cylinder 72 delta 88
