57 power brakes not working
Old August 28th, 2018, 08:03 PM
ivmachine's Avatar
I have a 57 olds 98 with a vacuum brake booster. The brakes don’t seem to be working much at all and the pedal is very hard to push. The check valve is working properly and I can’t find a leak anywhere. Everywhere I’ve the diagnosis is that there isn’t enough engine vacuum. The vacuum booster is ultimately fed by a vacuum connection on the center carb (3x2 setup). The center carb engine vacuum and the mechanical actuated fuel pump/vacuum pump both supply vacuum to the brake booster through this connection.
My question is, shouldn’t the engine vacuum be irrelenvent because the mechanical vacuum pump is also supplying sufficient vacuum? The booster was just rebuilt last year so I’m skeptical it’s the booster itself, unless it’s stuck somehow.
ivmachine is offline
Old August 28th, 2018, 08:36 PM
How much vacuum does the engine produce? Are there any vacuum fittings on the intake?
oldcutlass is online now
Old August 28th, 2018, 09:09 PM
ivmachine's Avatar
Only 12-13 in but I think I can improve that by adjusting the jets. I have the vacuum fittings and vacuum lines that match the shop manual. The vacuum pump produces like 20” of vacuum which I would think would be enough regardless of the engine vacuum.
toymobile
January 17th, 2017 07:32 AM
rmoths
Brakes/Hydraulic Systems
November 5th, 2013 05:00 PM
zodiacblueS
October 4th, 2012 06:22 AM
stratoblues
July 30th, 2012 02:46 AM
Steeb
March 23rd, 2009 01:56 PM
Quick Reply: 57 power brakes not working
